FINALLY… an intial report back. i’ll post a PDF of the build and how it all went together.
Went out with the finished(ish) article on tuesday evening – and WOW!! far far superior to the 20W halogen that was in the standard Lumicycle housing. I had to file the bottom of the LED board to get it to locate on the ‘flat’ at the base of a lumi housing. it all goes in nicely, and is chuffin bright. if anyone is after a 30quid delivered LED upgrade kit, then the basic cutter one is fab 🙂
there’s no heatsink in the unit at the moment – i made one but couldn’t fit it in with the other junk. But, it was used for an hour the other night, and the housing was only tepid when i got back, and the light showed no ill effects.
