Home Forums Bike Forum Converting a tripple cross chainset to a double
Viewing 2 posts - 1 through 2 (of 2 total)
  • Converting a tripple cross chainset to a double
  • hotgospeller
    Is a new front mech/shifter combo needed for this? Plus what is the ideal chainring (and cassette combo)?
    My Jake’s tripple chainset gearing felt to ‘hard’ so I swapped the 11-25 casette for a 13-30 and the middle ring now seems redundant (plus it favours the granny ring side of the cassette).
    Any thought’s on what’s best?
    psling
    What are you trying to achieve?
    If a triple (with granny ring) is too hard for you, a double set up is going to be higher geared again. Unless you are thinking along the lines of a MTB granny/middle only set up in which case you will probably have to change the front mech to one with a chain guide more appropriate to the smaller chainrings.
The topic ‘Converting a tripple cross chainset to a double’ is closed to new replies.
