Home Forums News Chipps with Everything: 2023 Eurobike Highlights
  • This topic has 11 replies, 8 voices, and was last updated 1 year ago by Gunz.
Viewing 12 posts - 1 through 12 (of 12 total)
  • Chipps with Everything: 2023 Eurobike Highlights
  • chipps
    Chipps brings you a curated tour of the eye-catching highlights of this pivotal European trade show.
    By chipps
    Get the full story here:
    matt_outandabout
    Me likey the kona in pink glitters…
    nickc
    I heard of one UK company with over 200,000 bike helmets on its shelves.
    Ouch, that’s some-one’s job losing nightmare.
    benpinnick
    Im surprised you didnt mention the 9,102,468 e-SUV bikes that were on show….
    3
    dovebiker
    No mention of the Cannondale mini-bike either 😉
    2
    b33k34
    Thanks for that insight into the industry – theres a lot of doom and gloom about (with the right wing press leaping on it as they love anything that suggests cycling is crap/doomed/etc).
    UDH I’m really dubious about. I’m pretty sure that not all UDH is actually universal – so the ‘direct mount’ mechs that are on the horizon won’t work with all the bikes that have a UDH now.
    More than that though it seems that what SRAM have designed a super cheap universal replaceable hanger that you’re unlikely to ever need to replace as rather than bending or breaking they just transfer all the load to your bike and risk breaking that instead.
    On our trip to Spain in May and I wrote off an XT 12s mech on day 1 and another on day 2 and damaged the frame, but my UDH was just fine…
    First time I knew I’m pretty sure I know exactly where I put the bike between two rocks. UDH rotates round and takes some carbon off the top of the seatstay, mech completely destroyed (both jockeys mashed, cage broken and bent, rear linkage on mech snapped in two) and into wheel bending a few spokes for good measure.
    Replaced mech, replaced UDH (which looked completely straight anyway) and half way through the next day, I was being super careful – I *think* maybe a rock came up off the front wheel – and again UDH rotates into frame, and a brand new XT mech snaps at the upper link that attaches to the UDH.
    I’d be really reluctant to buy another bike with UDH on – rather than bending a hanger and protecting the bike (and maybe even saving the mech) it seems you destroy bike and mech but dont’ have to replace a £15 hanger.
    Seems I’m not the only one thinking this (external link)
    benpinnick
    Sounds like the manufacturer didn’t add the rotation stop it should have.
    This is possibly true as there was an update to the UDH spec but _most_ bikes built to the older spec will work with the newer one. You’d kind of have to had deliberately gone out of your way to make it not work, but it was possible. It’s also worth noting that UDH is a spec, if your bike co wants to make a breakaway one, or one that bends easier, they could. As the MeatEngines writer says ‘The current UDH, as used on many bikes, is as good as any FIXED replaceable derailleur hanging in the history of mountain bikes’ which I think is fair.
    kelvin
    “An” update, or many updates? UDH compatibility doesn’t necessarily mean Transmission compatibility.
    And if you don’t want to fit Transmission, other systems arguably do the job better (if you consider part of the job is being sacrificial and cheaply replaceable).
    benpinnick
    There’s pre revision K and post revision K IIRC. Don’t quote me on the revision, but if you’re post revision K compliant it will work, if you’re pre-revision K compliant it may work. Ultimately you just need to ask whoever you’re buying the bike from if it will or won’t.
    b33k34
    What are you going to make the rotation stop out of? You’ve got to put a piece of carbon there, or affix a metal part, that’s going to have enough strength to stop a UDH rotating (with a fair bit of leverage from the mech).
    I’ve broken loads of mechs over the years, but this was two in two days, and both ended up in the spokes as well. I’ve not done two like that in 20 years of riding.
    I can’t help thinking that fundamentally a mech hanger that rotates backwards is a bad idea.
    1
    benpinnick
    Ours use a threaded insert with a steel screw. Ive tested it, it works.
    Gunz
    Is that Orange Switch really £1200 for an aluminium hardtail frame only?
