Home Forums Bike Forum Chainstay length.
  • This topic has 12 replies, 11 voices, and was last updated 10 years ago by JCL.
Viewing 13 posts - 1 through 13 (of 13 total)
  • Chainstay length.
  • scholarsgate
    Short or long? which is better? how does it affect the bike? does it just depend?
    Thanks.
    wwaswas
    short, easier to get the front end up
    long, more stability on steep climbs
    current trends seem to favour shorter = better and 1x transmissions have helped a lot with this.
    other areas (eg front centre) will have a big effect too so look at a package rather than just one measurement.
    anysize
    Shorter=more playful, longer=more stable.
    So, as with most things on a mountain bike, there is no better, just changing fashion. Recently the fashion has been to keep them short, but no doubt that will change.
    mikewsmith
    Long enough to fit the wheel in, depends what you want it for and what it’s bolted to
    scholarsgate
    I’m looking at 29er single speeds. Currently riding an inbred. Wondered whether a shorter chain stay would stop the rear wheel losing traction on some climbs.
    wwaswas
    For single speeds it’s more about where you position body weight and controlling your pedal input when climbing than frame geometry, for me.
    traditionally longer seat stays are seen as a good thing for climbing as they stop the front end wandering but your weight will be more on the front wheel as a result so maybe a shorter stay will shift your weight back a bit stood up.
    jameso
    It ‘depends’, yes. Shorter = better, we’ve been there before in about 1987?
    Balance is good; extreme numbers to get attention, maybe, maybe not?
    Not really, and your CS length will be dictated in 1/2″ increments based on your gearing. 32-18 gearing means a common CS of around 440mm, or a really short one at under 430mm (rarer)
    ahwiles
    shorter = crapper at climbing, but more fashionable.
    longer = crapper at manuals, but better at climbing.
    scholarsgate – Member
    maybe, but mostly it would just help you fall off backwards on steep climbs.
    Stevet1
    Bollocks.
    wobbem
    Bollocks.
    This ^
    jambon
    Long chainstays = boring bike.
    (having owned one that had long chainstays – old Giant Reign.)
    brant
    Oy mate, your chainstays are too long.
    JCL
    Yeah that guy needs a longer stem to put more weight on the front 🙄
    Anything under 430mm is crap on a medium unless you like large spring rate differentials and the unpredictable pitch stability that brings. 440mm is pretty good for a medium and +/- 10mm on small/large sizes is about right.
The topic ‘Chainstay length.’ is closed to new replies.
