Home Forums Bike Forum Cannondale Rush Owners Q.
Viewing 3 posts - 1 through 3 (of 3 total)
  • Cannondale Rush Owners Q.
  • KINGTUT
    What’s your weight and what pressure are you using in the shock, I’m 14st running 180 – 190 psi as per the manual and struggling to reach full travel.
    z1ppy
    How much sag are you running?
    Set the pressure to correspond to the 25-30% sag, ignore the manual.
    Not that I own a rush, but this is the usual guide for Single pivot bikes. 😀
    glenh
    Why run what the manual says? The manual doesn’t know how you ride.
    Set it as is best for you. Try a bit lower and see how you go.
    p.s. The standard shocks on the rush have an internal bumper fitted to limit stroke to 45mm (not the normal 50mm for a 190mm length shock), so you might actually be getting full travel if you were expecting a 50mm stroke.
The topic ‘Cannondale Rush Owners Q.’ is closed to new replies.
