That was a thoughtful review. Shame that the Rush damper doesn’t seem to cut it – sounds like not all Pikes can now live up to the reputation that they set with the introduction of the first Charger damper back in 2016.
The thing that made me decide against the Habit when I was trail bike shopping a couple of years ago, and would continue to put me off today, is the very slack angle of the upper section of the seat tube. If you run a ‘normal’ length seatpost, or a ‘normal’ amount of seatpost insertion then I’m sure it combines well with the forward-sloping lower section and everything works just fine. But if, like me, you have long legs for your height and raise your saddle close to the maximum, you end up way out back with a disproportionate weight distribution and a too-long cockpit.
Would have been better designed with a straighter seat tube and an extended pivot mount IMO.
