see you troll on here as much as on the chasetrails forum snakebite?
Do you spend all your life searching biking forums picking fault with other people? – sad, get a life!
If you dont have anything productive to say then don't bother
Brake cables are pretty much exactly as they came on the bike, gear cables have been changed and are not too long, the only one that is maybe a touch long is the front brake cable and TBH for the sake of an inch or so is it really worth f*cking around shortening it and bleeding the brakes etc – Formula Oro's are a pig to do at the best of times
Im really not that anal about brake cable length to loose sleep over it
The rest of the bike, gear cables included are well overdue a service and will get sorted as soon as I have a spare afternoon
Yep its not the best view for seeing the trail, but I did also have the Muvi mounted on the headtube and also on the camelback strap and have some footage from the camera mounted in same position but pointing backwards that is pretty cool
That is one of the big problems with the VHoldr / Contour over the Hero or other cams – mounting options are quite limited or brackets quite bulky
Like I said – 1st edit, when it rains and I have more time to sit in front odf a computer for hours I will finish the vid off.
