Home Forums Bike Forum Camelbak mule……..yuck!
Viewing 21 posts - 1 through 21 (of 21 total)
  • Camelbak mule……..yuck!
  • DarrenH
    Hello all,
    I've had my camelbak mule for around a month now and I've gotta say its an excellent piece of kit.
    However, I've got one gripe with it and you probably all know what I'm going to say here.
    It tastes gross! I thought the rank taste from bite valve would go in a couple of weeks, but no.
    Any tips to get rid? is it possible? or do you have to put up with the resuscitation dummy taste?
    Cheers.
    user-removed
    What have you been putting in it? I had no taste at all from mine until I tried a foul tasting powdered energy drink. It now tastes of chemicals. Bleh!
    simonfbarnes
    I hate those rubber valves and bought a Blackburn valve 12 years ago, which is still working fine:
    however I've not been able to find them for sale any longer…
    twang
    Add a bit of flavour to your water, I likes apple juice…snice!
    WorldClassAccident
    Milton tablet in a full bladder of water. Make sure you force the water down the tube and through the bite valve. Leave it overnight. Make sure you empty it and rinse before you use it.
    allthepies
    My Mule is years old and there's never been any taste from the bite valve.
    Onzadog
    bicarb is good for shifting nasty tastes. I've heard some people use steradent tables. Clean it all out and leaves it minty fresh!
    j_me
    Take the valve off, stick the hose on the steam nozzle on your Gaggia esprosso maker…..quick blast of steam….sorted
    twang
    That looks kinda industrial SFB, you put your mush round that?
    thomthumb
    old ones never tasted of anything – but my new one is awful – hoping it'll go away after some steradent treatment.
    simonfbarnes
    it's only 20mm across – I just hook my teeth on the outer lip and hold down the button with my tongue to get full flow. I used it for 10 years before I discovered it comes apart for cleaning :o)
    DarrenH
    I'll give the steradent a go, keep the ideas coming people!
    WorldClassAccident
    Milton doesn't leave the Sterident taste. I prefer it.
    scaredypants
    I just use one of these instead of a valve
    you do have to turn the tap on & off but it's easy enough
    BitterBaldingFatty
    I fill mine with pish after every ride. It doesn't taste of plastic anymore.
    thomthumb
    no; it leaves the milton taste – much more bleach like! ugh.
    tbf i use milton as well as it's a stronger cleaner.
    oldfart
    funny you should mention this.i have just got a replacement bladder and the first slurp always tastes vile but after that it's ok ?even after using miltons.
    grantway
    You can buy cleaning tablets and cleaning kit from Camelbak
    But ditti on the Milton or nay childs bottle cleaning fluid/tablet
    too.
    Wookster
    milton every time mate then keep the bladder in the freezer.
    easygroove
    bladder in freezer +1, good storage place and no nasties fester in the freezer
    montylikesbeer
    as above get some milton, works for babies
The topic ‘Camelbak mule……..yuck!’ is closed to new replies.
