Home Forums Chat Forum Building regs advice – window size
Viewing 5 posts - 1 through 5 (of 5 total)
  • Building regs advice – window size
  • wurzelcube
    I’ve attempted to read and understand the building regulations on window sizes, I know there is a minimum opening size of 450mm x 450mm to serve as an emergency escape but is there also a minimum aperture size for a room?
    I’m looking to convert a large upstairs bedroom (12 x 17 feet) into two rooms; the newly created room will be a small sized single bedroom (about 60 sq ft) . The room already contains two windows, one is large (1140x1140mm) and the other window is smaller (580 x 1000mm).
    The smaller window meets the building regs for serving as an emergency escape but I’m seeking confirmation that a window size of 580 x 1000mm ( the is the size of the aperture the glass is smaller) is satisfactory for a single bedroom.
    cynic-al
    Groupon etc?
    wallop
    Ring your local BC officer.
    psling
    You require 1/20th (5%) of the floor area as opening space since a bedroom is classed as a habitable room. You may also require background/trickle ventilation (usually in window frame). You seem to have means of escape covered.
    cotic853
    I think the 5% rule applies to windows that open wider than 30 degrees. If the window has a stay that restricts it opening any more than 30 degrees, then the opening pane has to be 10% of floor area. See Building Regs Part F
The topic ‘Building regs advice – window size’ is closed to new replies.
