Home Forums Bike Forum Brand X dropper no longer extending.
Viewing 8 posts - 1 through 8 (of 8 total)
  • Brand X dropper no longer extending.
  • monkeyboyjc
    My 170mm brand X dropper is no longer fully extending. It stops about half way, and needs pulling back up to full extension. It’s set at the correct pressure.
    So is this a warranty job (cartridge issue) or a simple service issue?
    Been harking on for years at their reliability too 🙄
    wzzzz
    Have you took it apart, cleaned and regreased?
    Topped up the pressure? They do lose a bit over the long term.
    If it’s in warranty, then just send it back for a new one.
    monkeyboyjc
    Does doing the service yourself void the warranty though…? That’s my next port of call.
    Onzadog
    Last time I saw this, it just needed the too bushing cleaned and regreased. Didn’t even remove the post from the frame.
    monkeyboyjc
    Thanks. Will give a strip down a try
    joebristol
    I haven’t had to do anything on my brand x droppers before, but my Oneup one has the same cartridge inside as far as I’m aware. It started to slow down on the return and only just make it to the top a while back. After a bit of Googling I unscrewed the top cap (with the post down) then extended the dropper. This pulls out the white bushing at the top of the post. It was quite dirty in there used the top seal so I cleaned it out and regreased it (slick honey). Reassembled and it’s been perfect since.
    yetidave
    looks an easy job, mine is getting done one night this week.
    monkeyboyjc
    Just service it ready for a ride tomorrow, and nope, still not returning. Also dropping pressure when adding air.
    Now off to the lbs to buy another and will ask CRC for a warranty on this one….
The topic ‘Brand X dropper no longer extending.’ is closed to new replies.
