Home Forums Bike Forum Brake piston spreaders
Viewing 40 posts - 1 through 40 (of 55 total)
  • Brake piston spreaders
  • 1
    bitmuddytoday
    Looking for some suggestions. Actual piston spreaders rather than the flat lever type. Birzman seem to get mixed reviews. Cough up for the Sram one? There are some cheaper identical looking knockoffs on amazon.
    I see Unior make one but not sure if that’s more for motorbikes?
    I’m sure I saw an ad for little expanding wedge bleed block size ones somewhere…
    bikerevivesheffield
    Have a look for a co. Called sumart
    tonyg2003
    I have one called “Ultimate piston press tool”  (very generic name!) from Amazon. There seem to be many that do roughly the same thing (sliding wedges with parallel expanding faces) on Amazon.
    It does make a job I dislike into a moment of workshop bliss.
    8
    hexhamstu
    too push for just jamming a couple of flat head screw drivers and wiggling them about with wild abandon? Well la di da
    1
    z1ppy
    I have the Birzman Double ended piston pusher, as I couldn’t face the cost of the SRAM tool. I was initallly disappointed, as the plates don’t push parrallel, once you start to press against the pistons. What I did find was using a large flat bladed screw driver, you can help the end that pushing in, and the tool works fine. Would I recommend it, over jamming two flate head screw drivers in, defnitely as you’ll struggle to damaged the pistons with this tool.
    If I was buying again now, I’d be tempted by that Sumart tool or a clone of the sram tool TBH
    masterdabber
    Flat headed screwdrivers and some old pads to protect the pistons.
    1
    benp1
    I love a tool but I’ve found a tyre lever works really well to open them up and haven’t had the need to get one
    Tool needed on a bigger caliper/system though (e.g. a car)
    jamiemcf
    I’ve an old Stanley flat headed screwdriver that was abused and the head rounded so I filed it smooth. Works a treat.
    tonyg2003
    It’s definitely the “luxury tool” end of tools since I have used the old pads/screwdriver for years. Which works, until the moment the screwdriver slips and the pistons aren’t parallel. Then it’s a pita!
    very much nice to have but not essential in the tool box
    3
    oceanskipper
    Occasionally using a tyre lever/screw driver etc can cause the pistons to become crooked and then they will never retract all the way. I had this issue and when I took to LBS to rectify the fact that I could not get the rotor in past the newly installed pads they got the SRAM tool out and went “oh yeah, common issue. This will fix it.” And sure enough it did. I then went and bought the SRAM tool and it makes fitting new pads, pad gap reset, pad advancement process a very simple job. Some SRAM group set components come with a plastic version of the tool that does a similar job but you can’t screw it in so less useful for mis aligned pistons I suspect….
    3
    Speeder
    Careful you don’t blow the bladder if it’s on Shimanos and you’ve topped up the fluid since the pads were new though.
    1
    oscillatewildly
    Has anyone got a link to the clone ones please of sram? I too want one of these as I’m forever chipping my calipers with screwdrivers etc would like a nice tool that does the job quickly and mark free- however the sram one is just not justifiable at all at that price but wouldn’t mind a cloned version or a cheaper branded one that does as good a job
    1
    Northwind
    I have a specific Massive ****-Off Screwdriver, it’ll never be used to do up a screw but with old pads in it’s an absolutely perfect piston spreader, the taper is just unimprovable. I’m all for a “proper tool” but in this case ime this works as well as the SRAM tool but faster and cost me like £3, so by keeping it in the bike tool rack it became The Proper Tool.
    bitmuddytoday
    https://amzn.eu/d/9M7HPNF
    Will probably get one of those. There are a few similar knockoffs. The Sumart looks good, but not sure where to actually buy one here.
    A largely unnecessary tool, but it’ll come in handy sooner or later. While using a Park Piston Press a few years ago I did manage to snap the pad bolt tab clean off a caliper. One of those “Did I really just do that!” moments. Peak ham fisted dumbass stuff.
    2
    twotonpredator
    I’ve the SRAM tool. Only used a couple of times, really had to crank it to get the pistons back in. Makes you realise that using anything else would have been bordering on the impossible. Also reduces risk of scratching the calipers etc.
    oceanskipper
    The Park one has a tendency to mark/put a ding in the calliper. Hateful thing.
    tthew
    Are the SRAM ones or their clones wide enough to do 4 pot calipers? Problem with them is that as you push back one pair, the pressure squirts the others put so need to be done all at the same time preferably.
    thorpedo
    I think the Park Tool press is meant to be inserted between the pads to push the pistons back, not contact the caliper body or pistons directly?
    devash
    Is this the SRAM one people are talking about?
    https://www.youtube.com/watch?v=OUQbv4NBQCU
    If so, seems like an interesting solution to their design fault (i.e. sticky pistons that easily misalign).
    I have one of these – https://uniortools.com/eng/product/1750-2DP-US-disc-brake-piston-spreader – which surprisingly doesn’t work that well with my SRAM G2 brakes *sarcasm*. Guess I’ll need one of those expensive official ones.
    1
    twotonpredator
    Yes, i’ve used it on Codes. Contacts both pistons on each side maybe 60% of the surface area. Has a hole in it to hold in place using the pad retaining pin
    oceanskipper
    Yep, that’s the SRAM one. That Unior is similar to the Park one which I don’t like.
    I tried the Park one with the pads still in and it’s even worse as it doesn’t push the callipers back evenly and also chips the pad material,  so if it’s supposed to be used that way it’s not great at all.
    devash
    Yep, the Unior and Park ones are supposed to be used with the old pads still in as they are made of steel and will damage pistons.
    The issue I have with them is that they don’t seem to work so well with SRAM 4-pot brakes because they don’t evenly push the pistons back in. Works perfectly with our bikes that have older Shimano 2-pot brakes.
    aberdeenlune
    I didn’t know the SRAM tool existed until I read this thread. Looks great in the video but a bit pricy. I’ve ordered an Ali express version for £20. Looks the same hopefully it will do the job well. Must be better than the screwdriver I currently use.
    PhilO
    The double wedge system looks like a sensible approach to me, at least over the lever types…
    Personally, I now use a C-clamp to *pull* the pistons back in individually. This (a) seems more positive, and (b) allows me to restrain one piston while ‘working’ the other back and forth to unstick things.
    b33k34
    I don’t see how the sram one or its copies would work with 4 pot brakes – which are the most difficult to deal with.  And it doesn’t actually put pressure on the pistons parallel, which would seem to be what you’d want.
    I’ve got a couple of the lever tools – a park one and something cheap I used to make up an order for free postage.  they’re best used with pads in and you have to be careful what you’re levering against.
    Best results I’ve had – as others have said, is using an old set of pads and a big screwdriver.  Especially if you twist the screwdriver rather than levering it.  the only tool above that seems to attempt to do the same is the birzmann and Zippy says you have to use screwdriver with that anyway.
    1
    kelvin
    I only learnt about this recently.
    Idiot destructor of Shimano levers.
    1
    kelvin
    I use the Park lever tool… with old pads in… but don’t take my advice (see above).
    2
    stanley
    After years of using screwdrivers, tyre levers and the “not great” Park tool, I’ve just ordered this Sram tool. Ordered from BikeInn for a reasonable saving; I don’t really like using them but better than supporting knock-off stuff imo.
    I’ve always managed fine without the proper tool, but I’ve rarely regretted buying decent quality, niche tools. So long as it covers more than half of each piston, then it should be fine with 4-piston calipers. We have pretty much the whole Sram range in our house so it’ll soon get tested. I’ll report back!
    oscillatewildly
    Do you not pay customs on the bikeinn site to the uk? I’m tempted treat myself too for xmas as it’s a tool I use a lot as I’m forever removing installing both wheels so inevitably everything goes out of whack over a few weeks and give them a good lining up again
    nwgiles
    I ordered mine from swinnerton today for £77
    stanley
    No additional vat or customs on the BikeInn site… think they use a distribution warehouse in the UK. Delivery sometimes takes longer than predicted though. Used them several times without issues.
    Whenever changing pads I like to pump the pistons out a bit, clean and lube the pistons, then squeeze them back in. Sometimes do it between pad changes as it keeps the braking performance good. Hoping it’ll make the process more satisfying 🙂
    cerrado-tu-ruido
    Leftfield option, one of them little air wedge thingies. I have never used one on a bike or otherwise so maybe talking total ….
    1
    GolfChick
    We have three of these Tyre Levers and they’re perfect for the job and don’t chip anything. Can’t imagine spending anything more than that for the job and that’s coming from me who loves having random tools for a job I only do once!
    1
    bikerevivesheffield
    The sumart universal bleed block/piston spreader is £39.99 from this dude but not in the country yet
    Screenshot_20241210-172935
    1
    stevious
    Dave Rome was very positive about these on the Geek Warning podcast recently.
    Beaut Bike Mini Disc Brake Piston Press
    He says he’s going to do a proper review of them soon but basically said they’re more versatile than the SRAM ones and don’t fall apart like the imitation SRAM ones.
    I don’t think they ship to the UK yet but hopefully it’s a matter of time.
    oceanskipper
    SRAM specifically say not to lube the pistons as it actually prevents them retracting properly rather than helping.
    It also enables dirt to get past the seal and causes damage to the seal.
    reeksy
    That looks to be the Sumart one rebranded. Out of stock currently.
    Worth noting that you need two for 4-pots and even then they may not fit (eg Magura).
    My standard issue table knife/tyre lever/screwdriver/whatever’s to hand will continue to be used I think.
    Tracey
    Use a worn down set of pads and an old piston retraction tool. Think it cost me £5 back in 2010.
    Never let me down and not damaged any pistons yet.
    A bit like this but it’s wider for 4 pots
    https://www.ebay.co.uk/itm/305761481528?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=hv5brc2stgc&sssrc=4429486&ssuid=eMMoTPPlT7y&var=&widget_ver=artemis&media=COPY
    infovore
    I 3d printed a pair of wedges; slide them against each other. Worked well, about 50p of filament. Found a few patterns for different caliper widths. (I was using with Shimano calipers).
