Home Forums Bike Forum Blind bearing removal tip
Viewing 5 posts - 1 through 5 (of 5 total)
  • Blind bearing removal tip
  • paulwf
    I needed to change all the bearings in my Cotic Hemlock.
    The main frame bearings were blind due to having a sleeve between them that had got stuck in place.
    I looked at the price of blind bearing removal kits (about £120) before realising that concrete stud fixings were pretty much the same.
    So used a M10 concrete anchor, drifted down the pin to splay out the legs and put a bolt in to keep them in place, and then drifted the bearings out easily from the other side.
    Now hopefully I can find a bearing stockist open on a Saturday morning!
    singlespeedstu
    Also works well when the bearing falls apart just leaving the outer shell stuck in the hole…
    retro83
    good work that man!
    paulwf
    4 bearing stockists around here and all Mon-Fri only 🙁
    I should have looked at it one evening instead of waiting until today!
    rob1984p
    I like that idea a lot, I was also impressed when I saw a repair stand on the pavement in Chengdu having a bit of trouble getting a bearing out of a person pulled rubbish cart, after a couple minutes difficulty he reached for the stick welder and blobbed a couple quick sparks between the drift and bearing and promptly hit it out, all while the public were wandering by.
The topic ‘Blind bearing removal tip’ is closed to new replies.
