thanks for replying here generalist!
@rubber yes I fell into the retun/enter trap. Embarassing :-)
@superstu yes it’s strange that Orbea haven’t fixed this. Searching in various Oiz FB groups for «bolt» it’s easy to see that many people have had this. Orbea should have fixed this and done a recall note. I believe that this is a safety issue – especially going downhill at speed.
After some investigation I believe the problem *might* be that the cylinder that go into the bushing eyelet of the shock doesn’t rotate. Instead the cylinder rotates around the bolt, weakening it until it snaps. I tried with som grease on the outside of the cylinder, and now it turns more easily inside the bushing. It will be interesting to see if the bolt snaps again.
see picture:
https://share.icloud.com/photos/0edoxO2yElFFYTVqlaxnBAZbQ
