Home Forums Bike Forum Best way to remove Uber BB dust caps
Viewing 5 posts - 1 through 5 (of 5 total)
  • Best way to remove Uber BB dust caps
  • TrailriderJim
    The plastic dust caps sit over the bearing so tightly they’re a bugger to get off without breaking them. Any tips?
    malv173
    I think a fine flat-bladed screwdriver should work, if you’re gentle. Or an o-ring/90 degree pick thing. Not actually tried to get mine off yet, though they are due a little attention.
    TrailriderJim
    I’ve found a method. Use a small, thin flat head (like an electrical screwdriver) and get it between the cap and bearing looking at the cup from the inside. You can then gently work it off applying a little force until it starts moving. But go steady, they’re very easy to break.
    malv173
    That’s great. Cheers for the update. I’ll have to get mine dealt with now.
    jamj1974
    Maybe use a thin Stanley blade…?
