Home Forums Bike Forum Best chain lube (which doesn’t gunk up?)
Viewing 40 posts - 41 through 80 (of 161 total)
  • Best chain lube (which doesn’t gunk up?)
  • molgrips
    Putoline also. Ridiculously tenacious and not at all sticky.
    I’ve done my MTB every month or so in the current filth, and when I get home from a muddy ride I just hose my bike off, put it in the garage and it’s spotless and ready to ride.
    It really is a game changer, if you’ll excuse the phrase.
    And it’s really not a long process. 5 mins for the fryer to heat up, dunk it, waggle it around a bit, then hang it up to cool down. I give mine a wipe when it’s cooled down enough to handle and get the stuff off the outside.
    molgrips
    That doesn’t sound so great. Realise it is the extreme short end but a lot of difference between one ride in worst conditions and the people claiming 3 months?
    For me it’s been 4-6 rides in the absolute filthiest conditions, meaning streams running down the climbs and wellie-losing mud patch type conditions. It probably didn’t need doing again, I was just playing safe. It has stayed silent and smooth the whole time.
    I’m not being paid by Putoline. I’ve tried most lubes in 25 years of biking and sure, some are a bit better than others. But Putoline is a completely different ball game.
    AlexSimon
    No mention of Rock n Roll Extreme yet?
    That’s been my go-to for years and I still love it.
    I had one bad batch where it didn’t have enough solids in it, but recently it’s been back up to form.
    Needs doing every ride in wet winters and costs quite a bit, but my chain is always clean, runs smoothly and seems to last longer than expected.
    kerley
    Will probably give it a go next year with new chain.
    tjagain
    Acidic soils with sand ie peat will strip the putoline out. Its the only conditions I have found that will and then only in extremis.
    I get thousands of road miles and hundreds off off road miles out of each application and also have the benefit of always having a well lubed chain and it does not collect on the cassette or attract dirt ( beyond and initial coating of dust)
    This chain has done half a dozen rides, still well lubed, no buildup
    IMG_1265 by TandemJeremy[/url], on Flickr
    milfordvet
    I think its different if your riding/ commuting daily or a weekend warrior.
    For the later, after I get home I wash my bike, let it dry in the sun, then spray the drivechain with GT85 to expel water and lubricate it and a loose wipe the excess off with an old towel snf clean the chainring(s). Then put it back in the room. The following week or so, before I ride I spray it with GT85 again immediately before I ride and wipe off the excess. No noise, no rust, shiny, no wear fabulous changes, no ‘de gunking’ or chain removal.
    Its a light oil that doen’t hold crud, gets in between links and lasts ‘long enough’ on a day ride. When you wash it off, it’s not heavy enough to stick on so the crud comes off and you don’t build up the residue that wears your drivetrain. Its the sweet spot for me between lubrication and not dealing with build up or application hassle.
    Muc off wet lube does leave a black gunky mess for sure. Never again. The Muc Off Dry lube put on the links individually, is excellent, just gets a bit pricy if you use it frequently. I prefer just GT85 spray, about £2 a tin. Worked for me for 30 years.
    If I was commuting, I’d likely want more ‘lube and forget’ stuff that hangs around longer. Not tried the Putoline or Squirt, so maybe I’m missing out.
    pampmyride
    +1 for putoline here too. Just started experimenting with the DIY candle wax methods as well.
    erictwinge
    been using Squirt for a while now but it doesn’t hang around as long as id like in the current conditions… returned to a rusty chain a few times over the last few weeks!
    certainly never any gunk tho.
    Digger90
    Is Putoline any better than Molten Speed Wax?
    I’ve been using MSW on my summer road bike in dry conditions for 18 months and been relatively happy. There’s a little more drivetrain noise than when using liquid lubes, but it’s acceptable.
    I get 300-400kms out of each chain wax before it needs redoing, and I wax/rotate 3 chains simultaneously, therefore I’m only having to cook/wax once per month.
    However, with MSW it’s a very different story when it comes to rain/wet and winter conditions:
    after just 1 wet ride rust discolouration starts to develop on the surface of the chain, and the chain becomes noisy. I’ve tried this 3-4 times now with the same result, and have gone back to liquid lubes for my winter bikes.
    So… is Putoline any better in that regard?
    molgrips
    Interested to see how you get on as I’d expect candle wax to be too hard and flake off. Putoline is sticky and semi-soft, like a cross between candle wax and CV joint grease.
    I do get light rust on the edges of the outer plates of the chain after I wash the bike and leave it to dry in the garage, but the lube is still well inside the chain and the drivetrain remains silent and smooth. Even when totally plastered in crud! Noise would tell me it needed re-lubing, and I get none.
    I have started spraying WD40 on a rag and wiping the chain after the hose-down, see if that helps. But I don’t think outer rust is important.
    nickc
    Aye the wax type are much better epically in this weather, if you can overcome your own inertia to actually apply the foul stuff in the first place!
    Ive found one (the Viking Lube) that for me at least does have similar properties (no build up, clean chain, and good lube for silent running) that works at least as well.
    Controversially I reckon the 12 speed cassettes suffer build up less than older 9,10 speed versions as well.
    Nobeerinthefridge
    Too right it is!! Buying a bloody deep fat fryer to oil a chain? What a waste! 😂😂😂😂😂
    reluctantjumper
    Another one using Peaty’s Link Lube, was on Wickens and Soderstrom No3 before and it’s the same stuff but with a blue dye in the waxy bit. Lasts a good 30 miles for my riding without any gunkiness, the only place it struggles is in the Beacons if it’s wet where it’s dead in 20. But then that soil just sucks any lube off a chain anyway, haven’t found anything that lasts longer in those conditions! I just carry a tiny bottle with me and top the chain up if needed.
    thisisnotaspoon
    That’s taking it out of context. The point you missed was that a lube that lasts to the end of (almost) every ride*, is much better than one that occasionally lasts 5 minutes leaving the chain bare for most of the time. And that >1 ride and ~3months can and do mean the same thing, it’ll often last for months, until you go out for a long ride on a really bad day.
    It will last three months of weekly rides. On the singlespeed it lasts three months of mud over the winter (just don’t clean the excess off when applying as there’s nothing to gum up!)
    *and bear in mind that the ‘almost’ is those days when you decide to try and ride the ridgeway in Febuary, or a bad 24h race when the course was just hub deep mud. We’re talking the extreme end of abnormal. I’m planning a HT550 ride this year and wouldn’t plan on taking chain lube unless the weather is looking bad enough to question going at all. I did 320 miles in a ride last year, including a fair amount off road, with about 12 hours of it in fairly heavy rain, and didn’t need to lube the chain when I got home.
    molgrips
    And yet, here I am doing it. Why would that be? Cos it’s much much better.
    Fryers are £15 btw but I got mine free from the local Facebook page.
    supersessions9-2
    I got a deep fat fryer for 7 quid from Tesco. That’s cheaper than a bottle of lube.
    I’m currently using paraffin wax. It’s good but a little bit too brittle. May look at different additives to improve it.
    ogden
    Anyone got a link to putoline at a decent price? I can only see it for £25
    tjagain
    That would be cheap. I paid £36 for my tin a while ago. It will last you for a decade or so
    Nobeerinthefridge
    Of course it is! You do it! 😂
    I’m off to service the sash windows, whittle my own spoons and hunt my own lunch.
    All faff, but so much better. 😂
    Paceman
    Muc-Off Dry Lube works great, shop around and it’s usually on offer somewhere.
    ajt123
    Can’t believe no one has recommended Rock’n’Roll Blue [Extreme] yet – excellent stuff.
    Goes on easily, cures fairly quickly, no mucking around with heating wax, stays clean, good in the wet.
    ajt123
    Ultimately, in a real bog-bath you’ll be wanting to give the drive chain a wash – I take mine off the bike and use the white-spirit in old milk container method.
    Given that is the case, you have to balance – you want it to last fairly well – but then be able to strip it off to get the dirt out.
    That’s where the super oily stuff like Finish-Line wet falls down – it stays on too well.
    thisisnotaspoon
    £24-£25 or so is the price it is, but you won’t need to ever replace it, I was going to as it’s now over a decade old, but then just cut the block in my fryer into 3, binned the bottom layer with all the crap in it, and the top layer which seemed light and greasy rather than waxy. The remaining bit will probably still do me another 10 years.
    tjagain
    ajt123
    with putoline you never need to clean a chain – see that pic of my bike – thats after several muddy rides. Retreating it cleans it as well
    reluctantjumper
    It was my go-to for a long time but then they slightly changed the formulation, something to do with it now being able to be sent by air, and now it’s not as tenacious. I’ve got the remains of a bottle of each and the new one smells distinctly less solventy and doesn’t dry my skin out anywhere near as much (always forget to use gloves).
    Littleman
    A couple of questions for the putoline fans on here if I may.
    I assume you degrease brand new chains before applying?
    I could live with the faff if the benefits are there, but how are putoline users dealing with removing the chain off the bike? – my and my wife’s mtb’s are both 11sp and sram and kmc state that their quick links are either not reusable or limited to 3 uses max. I know they’re arse covering and the links will probably last quite a few uses but I ‘d rather not risk snapping chains.
    I tend to use a descent wet lube this time of year but I haven’t got a specific one I must have, currently on Kingud which seems good in terms of collecting gunk. But, I only apply it very lightly and often. I ususlly run the chain through a chain cleaner woth degreaser every 3 or 4 rides which works for me during shitty conditions (season may not be relevant). Putoline therefore wouldn’t be too more faff for me really, I’m just not sure about regular chain removal.
    Also, when reapplying do you just pop the mucky chain in the fryer? Does the boiling remove the crap?
    Thanks.
    molgrips
    I did de-grease my chains before first application yes. Not sure how important it is though.
    You can just pop the chain back in the fryer – it doesn’t really get mucky. When I hose the bike down I put the water jet setting on the chain, it cleans out the grit, then I let it mostly dry and dunk it. Any water in there boils off like frying chips.
    I have always re-used quick links all the time. I never knew SRAM links had a limited use – in fact I suspect they didn’t until KMC put one on. However if you wanted to be really cautious you could remove the bottom pulley from your mech and if you are running 1x it’ll just pop off whole. It’d probably save handling the chain as your fingers do still get a bit sticky with Putoline even though it’s not a proper gunge-fest.
    Thinking about it – quick links are easier to undo after a few times – so perhaps they are technically a bit looser. But if you think about how it would have to fail, I can’t see how removal makes it any weaker in the normal way. And the only two chains I’ve had snap were SRAM and it wasn’t at the quick link – in around 2006-7 when they changed their manufacturing process leading to a load of breakages IIRC.
    molgrips
    I used to use it. Stayed on maybe two rides in the dry, in the wet – no chance.
    I wonder how you people are defining ‘works’? I mean.. your chain still goes round and your bike still goes forward, right?
    molgrips
    Not just me. I try lots of things, many are shit. Not this one though.
    If you’re accusing me of purchase bias, remember that TJ recommended it to me – I’m the last person on STW to admit he was right!
    Wally
    same Putline tub in an Aldi £10 deep fat fryer for 3 years now and I can see no real drop in levels or why another 3+ are possible. Try it- you will not go back.
    chiefgrooveguru
    “If you’re accusing me of purchase bias, remember that TJ recommended it to me – I’m the last person on STW to admit he was right!”
    I have to agree that this is one of those rare occasions when TJ is right! And Molgrips too. WTAF?!!
    nickc
    My understanding is that SRAMs limit is that links are not re-useable on another chain. You can break and re-join on the original chain as many times as you want. The prohibition means that the chain and link are worn out together, and a worn link won’t then compromise a fresh chain. I’m not sure about KMC chains though, sorry.
    I also have to say Putoline (and the other wax lubes) consistently come top of every comparison I’ve seen. I don’t use them as I can’t be arsed with the faff, but that’s not a reason that it wouldn’t work for others.
    chakaping
    I ordered some White Lightning Epic Ride off Amazon today.
    Was always my favourite clean lube, but haven’t been able to get it for years.
    Don’t tell them, but I’ve probably been re-using the same Sram links for five or more chains.
    Haven’t checked whether I’d died yet though.
    bone_idle
    GT85 is the best by far, but you need to use every ride, I never clean my chains just hose any mud off and retreat with gt85 then again before I ride. I spray that stuff any place that mud goes and it just drops off. All of my riding pals use it now nothing else comes close.
    Plus my drive train lasts alot longer. Try it it its cheap and smells luvvvly
    scaredypants
    Am I being thick – wouldn’t you have to saw the chainstay in two as well ?
    wheelsonfire1
    I’ve tested plenty of lubes as a mechanic and a rider in The Peak District. White Lightning clean ride is very effective even in thick mud, gritty conditions and rain. Make sure your chain is degreased and dry before use and apply to each roller. Rotate a few times, gently wipe off excess and leave overnight. The solution is best applied at room temperature (probably Californian) and shaken well between applications. However, it has surpassed expectations leaving a chain that just needs a very gentle wipe between applications and a clean cassette and chainrings. I’ve not needed to use a chain cleaner yet – it used to be after every ride! Just come back from a wet two weeks in Cumbria, no bike wash facilities and still good…Now I need to find a way to get rid of all the other lubes I’ve tested… Charity?
    molgrips
    Doesn’t everyone ride an Orange FS on here?
    No you’re right. I’m being astonishingly thick!
    molgrips
    You must be deaf. Or you don’t care about that loud rattling followed by actual squeaking that develops after about half an hour of riding with that stuff. I desperately wanted it to work, I tried so many times with meticulous de-greasing, but every time it just vanished long before the end of the ride, regardless of conditions. Yeah it might be clean, but that’s because it’s utterly devoid of lubrication, at least in my experience!
    No, it washes off in minutes again. You guys must just not care about grit, wear and noise.
    tjagain
    Moley – you are begging to sound evangelical like me!
    I find it incomprehensible that people pay £££ for a tiny bottle of ineffective lube when for a few £ more you can buy a kilo of a far better lube
The topic ‘Best chain lube (which doesn’t gunk up?)’ is closed to new replies.
