Home Forums Bike Forum Before any other T130 owners try…
Viewing 16 posts - 1 through 16 (of 16 total)
  • Before any other T130 owners try…
  • bacondoublechee
    Nope
    still no
    also no
    and definitely no.
    Fox Float X2 and Fox Float X will not fit on a Whyte T130 (carbon at least)
    Hope that stops you wondering!
    legend
    Try it without the shock pump attached
    paulneenan76
    Does it hit the frame?
    bacondoublechee
    X2 hits the linkage and frame or just the frame depending on which way you mount it.
    Float X hits the front mounting or the frame depending on mounting.
    sandwicheater
    Floor could do with a bit of a clean.
    pablogt
    First picture seems the closest, maybe try offset bushings pressed in at a 90 degree angle to push it away from the frame?
    Nice of you to post pictures to help others, My bike wont even fit a Corset or EVOL sleeve on the stock shock let alone an upgraded one.
    honourablegeorge
    Second X2 pic looks pretty close to a fit – looks like it would move away from the frame when sagged.
    But of tape on th frame and go for it, I reckon. What could go wrong?
    parkesie
    Get the grinder out.
    bacondoublechee
    Not a bad idea actually, might have another look at that. 8mm shock mounts though so only 2mm of offset.
    breninbeener
    On the Cane Creek ‘riders forum’ there are accounts and pics of people gently filing the corner of the air can so that it doesnt clash with the frame. The bike in question was a Cube Stereo HPC 160. It looks a similar interference fit 🙂 also using offset bushings at 90` to their intended orientation to space the shock away from the frame.
    bacondoublechee
    Monarch plus fits (no surprises there…) Have to remove the shock when you fancy a drink though.
    wiggles
    Or get a side loading cage
    yorkshire89
    Can you press in an offset bushing at 90 degrees, I thought the shock under compression would just spin it round?
    SirHC
    Over time they will, not a risk I would be willing to take!
    bacondoublechee
    I was wondering how that worked, wouldn’t like a big bottom out to spin everything round and leave you stranded – or with a cracked frame!
    leftyboy
    I have a 2015 Works T-130 and the warranty replacement shock is a Monarch plus so I better check it fits!
The topic ‘Before any other T130 owners try…’ is closed to new replies.
