Home Forums Bike Forum AXS XPLR users. How durable?
Viewing 23 posts - 1 through 23 (of 23 total)
  • AXS XPLR users. How durable?
  • 1
    tomhoward
    So I REALLY want to use wireless shifting on my next bike, but have no need for a massive 50+, or even 40+ tooth, cassette. I’m thinking of using an XPLR cassette and possibly mech, but the gravel mechs don’t have the overload clutch of their MTB counterparts. (The bit that allows them to take hits, not chain retention)
    i suppose my question is twofold, can I (preferred option) use an Eagle AXS rear mech with a 10-30 or 36t cassette? Or failing that, how much abuse will the XPLR mechs stand up to, crumple at the thought of a hit, or smash through would be destroying rocks?
    timc
    I find the jockey wheels clog up with crap much easier on my XPLR mech over my GX & XO mechs if that’s of any use to you.
    crossed
    I’m sure that when I looked in to doing this a while back the general consensus was that the Eagle rear mech wouldn’t/didn’t work with a 10-36 cassette. I think it works with the 10-44 but not 100% sure.
    benpinnick
    The clutch on the XPLR is too weak, I wouldn’t bother if I was you. I hear the new transmission RED one is stronger though….
    tomhoward
    But can I use an MTB Mech with an XPLR cassette?
    Daffy
    I agree with the comments about the weak clutch.  I’ve never lost a chain on my 1*11 DI2 GRX, but have lost it twice on Force XPLR AXS, even on something quite benign like jumping from a kerb.
    boomerlives
    I wore out the pivots on a X0 rear mech in about a year, so I don’t think durability is a strong suit for AXS/Sram
    jhpbk
    An XPLR cassette is 10-44
    If you are wanting a 10-30 or 10-36 thats just a standard road axs cassette
    Yes any of the AXS MTB mechs will work with the XPLR (10-44) cassette, no problem at all.
    But they struggle with a cassette under that, they will work, but you’ll find the shifting is a bit ‘off’
    tonyd
    No idea if Eagle would work, don’t see why not. Is this because you have one? I have Force AXS 12s on my gravel bike, 36T chainring and 10-36 cassette (XG1270). I’ve had no issues with chain drop and I’ve been down some real bone shakers – the kind where you can’t really see properly because you’re bouncing around so much 🙂
    tomhoward
    It’s for a DH bike. No need for big cassette, but also no need for flimsy road kit.
    Doesnt look like a DH specific AXS/T Type is on the horizon either, so trying to bodge, whilst not bodging, IYSWIM.
    Daffy
    No cassettes smaller than 10-44 in XD/XDR 12s as far as I’m aware, but if you’ve got a different freehub, you should be fine.
    tomhoward
    That’s my next q I guess, I know folk use shimano MTB cassettes with AXS, will AXS work with Shimano road?
    reggiegasket
    There are plenty of AXS/XDR cassettes less than 10-44
    https://www.sigmasports.com/item/SRAM/Force-AXS-XG-1270-12-Speed-Cassette/UDC9
    You can use an Eagle AXS mech on these, no problem. You could argue that a wireless mech is a tad overkill for DH but it’s your money 😉
    Not had any clutch issues with my Force AXS mechs (I have two). I’ve not crash tested them yet so can’t say much about the durability/crashability.
    jhpbk
    If you’re looking to bodge/makeshift something then this is really interesting –
    https://www.reddit.com/r/MTB/comments/10rgrqw/7_speed_axs_sram/
    And yep, we have used ‘AXS Mech/Shimano Cassette’ and ‘Shimano Mech/AXS Cassettes’ without a problem
    Everybody online says it doesn’t work, but it works absolutely fine in my experience
    Daffy
    reggiegasketFree Member
    I stand corrected.
    tomhoward
    from what I’ve read, it’s not possible to index all the gears, as the spacing is different to Eagle.
    might just get a couple of cheap shimano road options to try out with an AXS eagle mech, see how we go.
    Gotama
    Won’t road spacing be annoying with the narrow gaps between ratio ie you’ll have to dump three gears vs one on an mtb DH cassette?
    1
    jhpbk
    I have got far too interested in this for some reason.
    Just treid a XX1 Eagle AXS rear mech with a 10-28 AXS cassette and a 11-30 Shimano Cassette and it all worked absoltely fine
    Hope this helped!
    tomhoward
    Easily programmed with AXS 🙂 jumps between gears on DH cassette are 2 teeth anyway, so would only ever be 2 shifts.
    Daffy
    Hope this helped!
    Well, yes, it would.  What chain and chainring was it?  Certain chainrings and chains are tolerant of each other, but not the other way around.  From what I remember, SRAM chains prefer SRAM chainrings and don’t work well with Shimano chains.  This is why I have a WT chainring on SRAM cranks on a Shimano 12s XTR drivetrain.  Also, I think XPLR requires a flat-top chain to work with the rear mech correctly, no?  I have a FT chain on an XPLR 10-44 cassette, but the chain works fine on an Ibgrid cassette too, so the FT chains may work just fine with other cassettes.
    jhpbk
    It was a Eagle chain and a 32T XX1 +3mm chainring
    Although I have never tried anything else, I would presume of the ‘road’ groupsets designed with a flattop chain need that to work correctly.
    reggiegasket
    I’ve tried Absolute Black, Rotor CX1, Wolftooth, and Garbaruk rings with an AXS flat-top chain and they were all fine.
    (all narrow-wide, obvs)
    tomhoward
    Thanks all! Just what I wanted to hear. Everything I’ve read/enquired about has been quoting manufacturers, so indicated it was a no go.
    Stay Tuned!
