Home Forums Bike Forum Avid Elixir o ring question
Viewing 2 posts - 1 through 2 (of 2 total)
  • Avid Elixir o ring question
  • Netdonkey
    I am looking to shorten an Avid Elixir hose. I do not know the age of the brakes but was wondering if the o -rings have changed sizes at all across the years?
    ND
    JoeG
    You shouldn’t need any sort of o-ring to shorten the brake line.
    Above are the line fittings. The compression nut (the largest piece) can be reused, so you don’t need a new one. You need the other two parts, a tubing insert and compression ferrule. Both came with my bleed kit.
The topic ‘Avid Elixir o ring question’ is closed to new replies.
