I’ve just bought one to replace a worn out Tacx Neo 2 a broken Stages SB20 and an annoyingly squeaky Tacx Flux
First impressions are that its unbeatable for the money. You need to spend at least double to get a comparable smart bike. I’m not sure how much i will use the buttons and steering as I mainly only do erg workouts but its good they are there.
Pluses for me are
Easy adjustment between family members.
Fast response between resistance changes.
No bike needed.
Negatives
Not as quiet as I expected. Still very quiet just not as quet as the neo or stages.
The neo is the trainer gold standard and the Zwift bike it not far off and for most people I don’t think the differences will matter. The neo is more accurate for racing and definitely quieter but after about the equivalent of 25000 miles on zwift the resistance has gone and the fans run constantly on mine (if anyone knows how to fix this let me know) plus the plastics on the bottom have started to crack so its not really worth spending much to repair. The stages is unbelievably smooth but resistance changes are so slow that short intervals are nearly impossible. It takes about 20 seconds to go from around 250w to 500w meaning that by the time its stabilized the interval is 1/3 done. Its also really slow to react to cadence changes, again its probably about 20 seconds to go from 70rp to 100rpm. Its currently sat waiting for an engineer to come out and repair.
I would definitely recommend the Zwift bike for most people. Save the hassle of using your own bike.
