Home Forums Bike Forum Any one used locktite bearing retainer?
Viewing 4 posts - 1 through 4 (of 4 total)
  • Any one used locktite bearing retainer?
  • jfb01
    Just replaced the cartridge bearings on a full suss & one of them is too loose ,has any one used locktite bearing retainer?
    Does it work ,which grade should I use & most importantly can the bearing be removed in the future?
    Thanks for any help.
    Jeff
    trail_rat
    I have in the past to repair a yeti dh9 swingarm with loose bearings
    Worked grand.
    To remove em you have to use heat
    Oh and i wasnt aware of different grades…. Went to halfords , paid 20 quid for a wee bottle of bearing retainer
    eskay
    clean both surfaces with a solvent and it sticks like…….
    check out their site for the most appropriate one to use.
    jfb01
    Thanks for the replies.
    I will pop into a local shop which sells the stuff ,now I know it is a viable solution.
    Jeff
The topic ‘Any one used locktite bearing retainer?’ is closed to new replies.
