I agree with marksnook, you really need to prop all the way down to ground. It would help to know the age of the house and the roof covering, eg, tiles, thin slate, thick slate.
You might be able to minimise holes in the ceiling if you can locate the joists, and just make a small hole in the plaster to insert a solid packer. Unless you have a joist directly below the purlin, do that for 2 joists with spreader beams across the joists (above and below) and Acrows bearing on the spreaders.
The alternative to propping down to ground is a steel beam between load bearing walls. I wouldn’t rely on scaffolding planks to spread the load as they’re not stiff enough.
A car jack would be ideal for the short top prop, as you can get some load into the system.
(Retired structural engineer)
