Home Forums Bike Forum After a 29er 120mm fork.. any recommendations?
  • This topic has 18 replies, 12 voices, and was last updated 6 years ago by snaps.
Viewing 19 posts - 1 through 19 (of 19 total)
  • After a 29er 120mm fork.. any recommendations?
  • astura
    Contenders so far are as follows (all non boost)
    Rock shox Rebas RLT
    Rock shox Sid RL
    Magura TS6 (don’t know much about these)
    Fox 32 Talas FIT CTD
    Marzocchi LR320
    I am mainly doing XC but do like the odd drop off and jump 🙂
    TheFlyingOx
    X-Fusion Slide is 120mm 29″.
    Can’t remember what model it is but a mate has a travel adjust X-Fusion (think it’s 110-130mm) on his Pivot 429c and it’s superb. Can’t see why the Slide would be any different.
    astura
    IL take a look, IV been advised the maguras are not the best – however I can get them pretty cheap
    Onzadog
    I just bought a Fox 34 performance elite for £350.
    It’s a 44mm offset but I’m thinking I’ll not actually notice.
    daimo
    I managed to nab a 2018 120mm pike for £485 from chain reaction!!!!!!! That includes my 10% British cycling discount .
    daimo
    jimdubleyou
    Can I ask where? I currently have Float 32s but have fancied 34s for a while…
    Onzadog
    It was boost, but the 34 was/is available at CRC/Wiggle
    Whydot
    I recently got a set of Ohlins RXF34s. I like. A lot. Very coil-esque in feeling, track the ground very nicely, and very supple. Night and day when compared to my old Rockshox Revs.
    I didn’t get them new however, they are a touch spendy.
    snaps
    I might be selling these – brand new but they don’t match my new frame
    tomtomr
    Hi Onzadog,
    I don’t suppose you could let me know the 4 digit code found on the rear of the lower legs? I’m looking to see if these can be extended to 140mm with just an air shaft swap.
    Thanks, Tom
    vincienup
    My 120mm 29er is rocking a Yari which was a huge improvement over the previous Reba…
    gavinpearce
    Pike with 120 airshaft.  I could maybe sell you a pair if you are interested?  They are 2014, 140mm bought from and serviced by local bike shop (serviced recently in the summer).  Done about 800miles on them.  I also have the aforementioned 120mm airshaft.  Let me know if you are interested.  They are not boost.
    Onzadog
    @tomtomr.
    C7XC. Let me know what you discover. I might like to extend mine one day.
    shortbread_fanylion
    I had X-Fusion slides but changed them for X-Fusion Trace’s set at 120mm. They’re much better – track much better with the bigger stanchions, unsurprisingly. Whatever you go for I’d recommend 34mm stanchions as a minimum requirement.
    tomtomr
    Thanks Onzadog
    James from J-Tech has confirmed that the damper in these is limited to 120mm. To extend the travel you’d need a new damper (£250) as well as the air shaft.
    Tom
    Onzadog
    @tomtomr, cheers. J-tech is where I went for the evol air spring upgrade for these.
    I did look at the spec from the code. It said 120 but it wasn’t clear to me if that was meant as the maximum travel or the current travel.
    tdog
    @snaps, just outta interest seeing as they are gorgeous and all that jazz- how much?
    snaps
The topic ‘After a 29er 120mm fork.. any recommendations?’ is closed to new replies.
