Home Forums Bike Forum 33/18 as an SS ratio, yes or no?
  • This topic has 15 replies, 13 voices, and was last updated 9 years ago by frood.
Viewing 16 posts - 1 through 16 (of 16 total)
  • 33/18 as an SS ratio, yes or no?
  • 2unfit2ride
    As above on a 29 er, it’s just for relaxed rides to the pub, no racing!
    Cheers.
    mtbfix
    Assuming the pub is 47miles away over 4 Lakeland passes it may be a mite stiff.
    breadcrumb
    SS ratios are hard to answer.
    How hilly? How fit? How stubborn/determined?
    I run 32:19 in the lakes.
    takisawa2
    33 / 18 on my Niner.
    It’s frustratingly spinny on the road.
    Currently running it 33 / 16 with b+ / 29+ combo, & it’s a bit better.
    If it were not seeing anthing hilly I’d be looking 36 / 16 minimum.
    2unfit2ride
    Thanks peeps, I guess I’ll suck it & see but 32/16 is ok for me on 26″ wheels.
    rOcKeTdOg
    32:18 on my 29er, 33 would be just as good (& less spinny on the flat)
    kerley
    It is only 1 GI higher than your 32/16 on 26 wheel so should be very similar (52 vs 53)
    Both way too low for me but as said above everyone needs different gearing based on their fitness, area riding in etc,.
    DrP
    It’s pretty close to the 2:1 (26at) ratio that defines the men from the crabs.
    Or something like that..
    DrP
    benji
    I run 30/18 on a 29er but i’m a spinny kind of rider.
    dawson
    Anybody any thoughts on an oval 34 over a standard 33?
    Do the oval rings help enough on climbs to go 1 tooth higher?
    andyv
    33/18 sounds perfect for a 29er. Make sure you have a thick/thin chainring.
    Personally I run a 32/18 in a weighty steel sawyer and managed SSUK just fine.
    StefMcDef
    Just gone to 32:18 from a 1-key oval 34:18 on the moderately hilly Isle of Wight.
    Got on fairly well with the oval chainring as an actual gear ratio but found it skipping off quite a bit. Hard to maintain an ideal tension on it with the EBB on my Selma.
    2unfit2ride
    andyv, can you recommend a 33 thick thin ring please 😉
    DrP
    I geddit…!!
    DrP
    DaveyBoyWonder
    I run 32:18 on my 26er in Calderdale. Very spinny on roads but off-road its generally fine.
    frood
    thick/thin rings are unnecessary for an SS build anyway. If anything it’ll just wear quicker than a proper SS chainring
The topic ‘33/18 as an SS ratio, yes or no?’ is closed to new replies.
