Pivot switchblade r...
Pivot switchblade replacement cable cover bolt & rivnut?
3 Users
1 Reactions
Damn. Just went to remove the cable port and the little bolt was tight. Instead of the thread coming loose the collar in the frame came away. Thankfully I was able to remove it with light persuasion.
I think there is enough material left to epoxy a new one in, is that called a rivnut? Any idea what size, Google search suggest it might be M3.
Posted : 09/11/2025 3:44 pm
I'd email Pivot and ask their advice. They're pretty good at responding from experience.
Posted : 10/11/2025 12:34 am
Or for somewhere a bit closer to home (assuming you're in the UK) try contour cycles.
https://contourcycles.co.uk/
Posted : 10/11/2025 8:13 pm
