Bleeding new XT bra...
[Closed] Bleeding new XT brakes
7 Users
About to fit and tinker a set of these at the weekend for a friend.
I've heard that the olives can be reused and you can use a syringe (without plunger) instead of the yellow funnel.
Is that true or do I need to go shopping?
I've got a sealed pot of cyclo mineral oil. Will that do or is it worth getting a small bottle of the Shimano stuff?
We're it DOT 5.1 I'd just be off the the nearest car parts place. Oddly, I don't have much dealing with mineral brakes.
Posted : 20/08/2013 9:15 am
I use two syringest with plungers to purge bubbles out both ways. So you don't need the funnel. Also heard olives can be re-used and if you're cutting cables, you can do this without a bleed if you're careful.
They can be a little difficult to get all the bubbles out.
I have use a non-shimano mineral oil to no ill effect.
Posted : 20/08/2013 10:11 am
Updated instructions for syringinging
http://www.epicbleedsolutions.com/blog/how-to-bleed-new-shimano-brakes/
Posted : 20/08/2013 10:14 am
Use the instructions that Rob has linked to there and you won't go wrong.
One thing I'd add is to pump the lever a few times without the wheel in to being the pads closer to the disc once it's fitted. Makes for a much nicer lever feel.
Posted : 20/08/2013 11:22 am
I've shortened hoses without bleeding. I wouldn't reuse the olives though, mine came out pretty crushed, up to you though.
Posted : 20/08/2013 11:28 am
Cheers folks. So, do I take it the olives are split now like the hope ones?
Posted : 20/08/2013 5:17 pm
My olives where not split and were one use only. XT brakes usually come with spares olives etc to allow you to shorten the hose.
Posted : 20/08/2013 6:24 pm
Epic bleed kit is cheap and easy to use..
Posted : 20/08/2013 6:30 pm
