Those mats are 15mm thick, weigh 40kg each (6′ x 3′) and are for gyms, so I was hoping they’d protect the floor. However, obviously not….
So I spent most of this afternoon repairing the floor and building a proper Olympic weights platform:
Using a very nifty tool I found recommended on STW, I cut out the collapsed bits of 18mm Ply:
[/url]
Cutting out the broken bits[/url] by brf[/url], on Flickr
[/url]
Barbell damage[/url] by brf[/url], on Flickr
The insulation under the Ply was crushed, so I replaced the duff section with some old fence posts to re-inforce that spot:
[/url]
4" fence post used to repair insulation[/url] by brf[/url], on Flickr
Covered it all in foil to keep a complete vapour barrier:
[/url]
Foil Vapour barrier[/url] by brf[/url], on Flickr
[/url]
Repair complete[/url] by brf[/url], on Flickr
So I need something more robust under the bar:
[/url]
Barbell impact zones[/url] by brf[/url], on Flickr
Using 3 sheets of Ply, I made a 7′ x 6′ pad, with triple layer 18mm ply on the outer 2′ each side:
[/url]
Ply base[/url] by brf[/url], on Flickr
I cut up the 15mm rubber sheets to cover the edges and filled the middle with scraps of 18mm ply:
[/url]
Matting on top[/url] by brf[/url], on Flickr
I put more rubber mat in the middle section with a final cover of Ply (as it gives better grip for shoes):
[/url]
Untitled[/url] by brf[/url], on Flickr
So there are now 4 layers of Ply and 1 layer of matting over the Celotex, which hopefully will last a bit longer…..
