Needs more cephalopod.
Looks about right? From memory, the one I had on my 456 I just tried to put it in the same sort of location as a front mech would be.
Move it further forward if you feel the need, but surely it'll narrow the up/down gap the chain can go through at the extremes of the rear sprockets. If that makes any sense?
What gear ratios you running? I was just contemplating going 1x9 on my FTM.
Post some pics of the full build!
I rotated mine so that when in the smallest cog - the bottom of the guide wasnt rubbing on the chain. Then moved it up/ down so that it didnt rub in the biggest cog. Plus some final tweaking.
What cog are you in there?
pissing me right off - in the 36t at teh back it forces the chain off the front ring and i cannot see/understand how to remedy it!
in the pic it was in the 11t at the back
Buy an e13 xcx. Perfect remedy. Took five minutes to fit and been flawless since.
Some things are worth paying a little extra for...
how would it make any difference jam bo or are you just being your usual provocative and pious self?
surely if it's not holding the chain properly move it further back, not forwards - you have to stop the chain "derailing" and it can only do that before it locates on the chainring teeth ?
11t! Oh. You have some tweaking to do!
On mine - in the 11t the chain should be almost touching the lower "bolt".
I'll try and get some photos of mine tomorrow.
In the meantime - rotate it forward a good bit. It'll start to rub the ring - so move it up as required. Leave it in 11t.
Would probably help if you ran a ss specific front ring, longer teeth hold the chain better. Myself & a friend both swapped to 1x9 using the superstar device I've not dropped a chain & he's had all sorts of dropping & jamming issues. The only difference is I use a ss chain ring.
Well it would work for a start and you wouldn't be getting all pissy.
I'd say that was worth about £15 extra...
Propper ring at the front would sort your problem.
Well at least until the guide block breaks.
Then you could replace it with an E13 and have no more problems. 🙂
sss - new unramped ring comes this week
have had one of these for a month or two, but gone back to triple as got fed up of chain jamming and general faffing around, was using a standard 34t ring, is the general opinion that a specific single speed ring(longer teeth) would solve the problems of chain loss?
Got one myself & use Hope SS chainring. No probs, but I do ride like pure gheylord. 🙂
Do you have a spacer in beside the chainguide bracket at the BB? Put 2 spacers on the non-drive side if you do?
What jam bo and SSStu said... Only don't replace it with an E13 top only guide, replace it with an E13 or MRP full guide, top and bottom...
The Superstar XCR is the shittest, least reliable chain guide on the market bar none... Read some of the threads on it on here... Anyway... You are also running a ramped front ring, that is designed for it to be easy to shift from it to another in a multi ring setup. This is not helping in any way, so get yourself a proper unramped ring and that will also help no end.
For the record, MRP Lopes chain device, unramped Gussett chainring, 11-36 1x10 setup and it all works flawlessly, no matter where. When I had a Superstar XCR, I'd drop the chain at least once or twice every ride (the guide would bend, and the chain would jam in it), which defeats the whole object of going 1x10 for simplicity and reliability.
1x10 here with XCR guide. Working perfectly. Never loses the chain. Take a bit if time to set it up right & you'll be fine.
Of course, you could splash out on overpriced E13 kit.
I mean, it costs loads so it must be better right...surely...
In this case, I'd say yes.
Seconded.
Anyone know if this is (definitively) unramped:
http://www.chainreactioncycles.com/Models.aspx?ModelID=28192
I've had no problems with my XCR guide. Takes a bit of time to line up but its a chunk of plastic on shaped piece of metal. Not really anything to go wrong.
There are some poor reports of the seat tube mounted one, but the bb one has had reasonble write ups I thought.
I also had no problems using a ramped chainring.
I was thinking of going single on the front. Only use the middle,but it seems like a lot of aggro and I can't be bothered!
Rob, just get something like a Blackspire mono veloce chainring - it whatever size.
bought a truvativ dh ring - unramped
that'll do the job
Truvativ DH chainring and 2 washers - all works spot on on the workstand now 🙂
I've got the superstar running 1x9 with a rental 32t ring. Works spot on, I run the guide quite low, just clear of the chainring arms from memory
