I think my XTR clut...
[Closed] I think my XTR clutch is broken...pics
[#4844074]
Evening,
A few weeks ago my XTR shadow plus mech instantly became much stiffer in feel at the lever.
Today I opened it up because I'm a bit fed up with it and tried loosening the clutch off which has no affect. What I noticed was this...
...if you look closely you can see that something has cracked/snapped and I feel this may be the culprit, can anybody confirm that it should indeed [u]not[/u] be snapped like this?
Assuming it is broken, what do people reckon to warranty claims with Rose?
Any help greatly appreciated.
Will
PS. I know it looks mucky in there, should've cleaned the bike before taking the cover off!
Posted : 06/02/2013 9:55 pm
Best mail them I guess...
Posted : 06/02/2013 10:01 pm
Every time you removed the rear wheel did you remember to switch the clutch mechanism off beforehand?, that looks suspiciously like what happens if you force the mech to move whilst removing the rear wheel from the frame.
Posted : 06/02/2013 10:06 pm
Yes, definitely swithched it off to remove the wheel. Rarely take the wheel out at all.
Posted : 06/02/2013 10:08 pm
The plate shouldn't have a crack in it but I can't see how that would make the shifting stiffer.
If anything it should have released a bit of tension in the clutch band making shifting easier.
I'd say the muck/rust on the clutch drum thingumy would be making it stiffer.
Posted : 06/02/2013 10:12 pm
In that case i suspect the lower cage of the mech has been subjected to a whack at some point forcing it to move despite the clutch being applied, but like stu says that is just the clutch stop tab and if it is loose the shifting should be slightly easier?. Lube everything and try shifting.
Posted : 06/02/2013 10:31 pm
Are you sure those 2 red circles are supposed to be loose?
Posted : 06/02/2013 10:44 pm
But seriously, having just had a good look at mine (off the bike) and cross-referencing with the docs I'll link to, I'd say it's the rusted part that's caused your problem.
Although [url= http://techdocs.shimano.com/media/techdocs/content/cycle/SI/XTR/SI_0120A/SI-0120A-003-00-Eng_v1_m56577569830789046.pdf ]THIS[/url] doc doesn't give any schedule, it would be safe to say that it probably requires a re-lube fairly frequently if being used in mucky conditions. If you have a look at parts 5 and 15 of [url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-M985-3156A_v1_m56577569830799960.pdf ]THIS[/url] doc it uses the term [i]seal[/i] and [i]packing[/i] respectively, which to me suggests that what I thought was a seal of the service cap is simply packing to stop what I presume would be an annoying rattle if assembled without it.
Anyway, I think water can get in via the pivot shaft, possibly even through the p-seal (I'd have to dissassemble to be sure) if it becomes submerged. Regular, preventative maintenance is definitely something to consider with this particular component IMO.
Posted : 11/02/2013 1:37 pm
cheers bud you are right
Posted : 02/04/2013 10:11 pm
There's an off button???
I've got one of these and had no idea at all. Haven't had the rear wheel off yet fortunately so at least I found out in time!
Posted : 03/04/2013 8:34 am
