Viewing 40 posts - 1 through 40 (of 97 total)
  • Car won't stop!
  • molgrips
    What a bonkers 24 hours this has been for my poor Passat B6 2.0 TDI auto.
    Last night, drove home no issues. I couldn’t sleep as it happened, so came downstairs to watch telly, the alarm’s going off. Odd no break-ins, car is locked. Unlocked and locked it, still kept going, then it stopped on its own later.
    Came to drive today, totally dead, . So I removed the battery and the alarm went off! Wtf, there must be a spare battery somewhere to power an alarm when the battery’s disconnected. Well that explains last night – something was draining the battery and it went low, alarm went off.
    Charged the battery just now, drove to Tesco. It was a bit confused as usual after a flat battery – ESP, power steering lights on, cruise control doens’t work – this usually sorts itself. All lights off by the time I got to Tesco, no worries.
    On returning to the car, I see that the BRAKE lights are on (not tail lights) despite me having locked it. Weird. Well on the way back a few other lights are on that weren’t on on the way over. Not so good. I get home, turn off the car, the engine doesn’t stop! Remove the key (it’s one of these push-fob things), still running, get out lock the doors – still going. So I disconnected the battery, the aircon etc stop but the engine is still going! It’s still going now, I’m waiting for the breakdown man!
    WTF? Seriously!
    skaifan
    stall it
    molgrips
    Automatic.
    fbk
    Exorcism?
    cloudnine
    Its probably pretty hard to stall an automatic
    djglover
    Drive it into a canal
    piedidiformaggio
    mboy
    stall it
    Not easy to stall an Auto box!
    Running on its own sump oil? 😉
    More than likely though, you’ve got some serious electrical gremlins manifested themselves, and you need to get it connected to a VAGCOM asap and get the fault diagnosed and fixed.
    IanMunro
    Wierd. Why can’t you just put it in gear and stall it BTW?
    Too slow 😀
    cloudnine
    Low battery power can do weird things to the ECU as the car tries to ‘power manage’ what there is.
    wallop
    I once had a car which wouldn’t switch off – I was driving down an A road and the turbo had started to use the oil sump as fuel (or something like that). Anyway, there was loads of smoke and the car behind me phoned the fire brigade and I got a lift in a fire engine. It was quite exciting.
    Jamie
    IanMunro
    [video]http://www.youtube.com/watch?v=WrAeUf7v49g[/video]
    molgrips
    Really? 🙂
    Any ideas on how to stop it? I’d unplug the ECU but that doesn’t seem to be particularly easy. I considered clamping the fuel line but I really don’t want to wreck any expensive high pressure fuel pumps by starving them (or overloading them if I clamp the return instead of the inlet).
    spooky_b329
    Block the air intake with something that can’t get sucked in, rubber floor mat or something. You can also use a C02 fire extinguisher if you are desperate, but don’t freeze your hands to the nozzle 🙂
    Sounds battery/alternator/earth strap related.
    mintimperial
    I once owned a Fiat Panda auto (don’t ask) that stalled roughly once every couple of drives. Bloody awful car, that was.
    Personally I’d be calling up the local priest to carry out an exorcism.
    Mikeypies
    get some thick plastic and cover your hand then block the exhaust
    molgrips
    I did consider blocking the air intake. Dunno how much suction would be generated as it opens the throttle to keep the revs up.. could be nasty.
    On my old car I put my hand over the inlet and it really sucks like hell. Definitely not doing it with my hand.
    spooky_b329
    Better to stop the air and suffocate the engine than try and strangle it by blocking the exhaust!
    spooky_b329
    If it throttles up it will need more air. Just don’t use a plastic bag as it could ingest it through the turbo.
    spooky_b329
    P.S Too late now but you should never disconnect the battery with the engine running, it can kill your alternator.
    molgrips
    Yes and thence suck harder, possibly causing some damage or other. Disconnecting the ECU would be best I reckon.
    IanMunro
    Cellotape some cushions to the front and drive it very slowly into a wall.
    andyl
    i would hope the air filter would block a plastic bag!
    Did you drive back in the rain? Check for some connectors that can easily get wet around the front or wheel arches as it sounds like the ignition circuits are getting kept live. To stop it you could undo the battery as a modern diesel needs electronics and then turn on every electrical item (lights, stereo, rear heater etc) and press all the electric window buttons up when closed to try and use all the electricity the alternator can supply.
    verses
    My car has a fuel cut-off (under the passenger seat IIRC) does your manual mention anything?
    molgrips
    No, no rain.
    There was a slightly odd smell in the car, a little bit like burnt electronics… I at first thought that the 5v power supply I’d bought off ebay a few weeks ago to power a USB HD had burned out somehow and drained the battery. Reinstalled the original radio before I went to tesco just to be absolutely sure about the current drain. I’ve suspected the aftermarket stereo before.
    Will check!
    glenh
    trail_rat
    Taking the battery out is a bad idea esp as the alternator will keep it going even with everythjng on – the revs will just climb a bit to counter the load
    spooky_b329
    If you decide to unplug the ECU I’d be leaving that to the AA man. Could cause all sort of issues, sensitive electrickery and stuff. Might not even make any difference, its probably the stop solenoid stuck open which would normally close when you turn off the key/the battery goes flat.
    I don’t think blocking the intake can cause any damage, it will just lose power and refuse to rev, if you get a good enough seal it will stop. The suction is only created by the combustion.
    The alternator will be able to supply around 90amps…you’ll never consume that much power (except for the starter). I didn’t think about the alternator supplying the stop solenoid. I suppose you could disconnect the alternator earth strap but probably hard to find in the dark, plus it could kill the alternator if its not already dead.
    CaptJon
    Can you block the air intake? Don’t know if that is a good idea or not.
    trail_rat
    Mikeypies
    just block the exaust, it work or it did on my dads morris ital I’m sure nothing has moved on much since then
    trail_rat
    What about a co2 fire extinguisher at te air intake ?
    singlecrack
    Burn it ….
    spooky_b329
    How about you jack it up, get it into drive and up to speed and then knock it off the stands. If it is a robotised clutch rather than a traditional auto I bet that will stall it. Remember to leave the cushions in front of the car 🙂
    Junkyard
    I struggle with long sentences
    Disconnect the fuel supply
    verses
    Actually thinking about it, I think the fuel cut-off switch in my car just re-enables fuel once it’s been cut off when the engine detects a problem. It doesn’t allow me to disable it.
    adscatt
    Ignition switch issue? Pull fuel pump relay or power supply relay out of fuse box, not sure of relay numbers from top of my head. That model Passat suffers from immobiliser issues (inbuilt into convenience ECU behind the glove box) and also electric steering column lock ECU issues.
    snaps
    Open the water drain on the bottom of the fuel filter & it will draw in air & stall.
    molgrips
    Very very messy. The pump would continue to run for a fair while. Bear in mind the engine’s really hot at this point and hard to work on!
    Green Flag man removed the big relay from the fuse box – job done. Brake lights permanently on now though – battery is now disconnected.
    The possibilities:
    1) It’ll reset itself overnight off the battery
    2) It can be reset with VAGCOM at the garage
    3) It can be completely reprogrammed (Green Flag man suggested a normal performance remap..?) and will work
    4) The wiring loom’s damaged and confusing the ECU
    5) The ECU’s totally borked.
The topic ‘Car won't stop!’ is closed to new replies.
