Home Forums Bike Forum Yeti bearing kit – easy to fit?
Viewing 4 posts - 1 through 4 (of 4 total)
  • Yeti bearing kit – easy to fit?
  • will1
    Need new bearings in my ASR SL frame. Is this easy to do? Or should I let the lbs do it? Thanks
    konahead
    Changed the bearings on my ASR over Christmas. Pretty easy job using the ‘Rate link tool’.
    I used the tool in various combinations of washers, sockets etc to remove/fit all of the bearings. Got a bit Macgyver at times though…..
    I found a pdf on t’internet showing how to remove/fit all bearings. Had a quick look but can’t find it now – I’ve got a saved copy, let me know your email if you want a copy.
    will1
    konahead that would be helpful. Cheers
    wandywilliams@aol.com
    konahead
    email sent
The topic ‘Yeti bearing kit – easy to fit?’ is closed to new replies.
