Hi all
I’ve somehow managed to snap the clutch lever off my XTR M9100 derailleur.
It snapped in the “on” position, so I’ve just been riding it for a couple of months like that.
At the weekend I was popping a wheelie and cranked down hard, then there was a bit of a gears crunch and the chain went all floppy.
The jockey wheel mount is basically not where it should be with only a little movement.
I’m trying to get the what’s left (not much) of the lever out, but I can’t turn it to the “off “setting due to the lever now being a flat stub – therefore I can’t remove the clutch (I assume that’s why anyway).
I’ve removed the cover to the clutch, but the clutch itself won’t pull out. It’s stuck fast. I assume because of the pressure on it from the clutch being “on”.
Anyone have any idea how I can turn the clutch off without a lever, or how I can remove the remains of the old lever and/or the clutch.
Thank you all in advance 🙂
