Home Forums Bike Forum XT V-brakes
Viewing 15 posts - 1 through 15 (of 15 total)
  • XT V-brakes
  • miner29er
    I’m thinking of putting some brand new XT v-brakes on my GT Avalanche with a rigid steel fork. A few years ago they had a reputation for being squealers – front in particular. Does anyone know if things have improved with them?
    gears_suck
    I’m not aware of any such reputation.
    alexpalacefan
    The parallel push ones are. Is that the sort you propose to use?
    APF
    thorpie
    I have modern ones on my 97 Cindercone and they are excellent. No squeal, M770 I think or something similar.
    Trevor.
    cakefacesmallblock
    I remember lusting after XT vees, when my STX-RCs had me into parts of the landscape I wasn’t intending to ride.
    …………..If I were building retro or pub bike they’d go on though.
    miner29er
    This was my source of the “squealing” reviews http://www.mtbr.com/cat/brakes/brake-system/shimano/xt-v-brake/prd_350747_108crx.aspx
    It might have been the old parallelogram action ones that were squeaking. Thanks for comments – it appears that Mr S might have solved the annoying problem now. I’ll be buying modern ones like thorpie uses 🙂
    timwillows
    My ’99 XT Vs squealed, well the front one did. Cured it by fitting XTR
    TheGingerOne
    Yes, back in about 95′ they did. I just found the remnants of the ‘upgrade’ Shimano sold at the time to resolve the issue. Essentially they were very thin almost paper like round stickers that you stuck on to pad out the sloppyness in the parallelograms. Worked a treat, though cost a lot comparatively speaking for what they were.
    emanuel
    avid sd7 levers and brakes.
    finbar
    MIne squealed like mofos. Much prefer Avids.
    chrssmale
    Its been about 5 years since I had XT V’s. From what I remembered the pads that came stock did squeal abit, though mostly in damp/wet conditions, was fine in the dry. I replaced the pads with more expensive cartridge type ones and also ensure you set the pads to toe in.
    mattbee
    I run the old parralel push XTs on my Bonty, they don’t squeal for me, but I do have ceramic rims.
    bigyinn
    IIRC M760 XTs were the last parallel push v brakes shimano did and they were good. No slop, no squeeling.
    miner29er
    Thanks all – this has been very helpful. I’m gonna go for ’em. I should be using them at Llandegla on Saturday. Listen out for me if you’re there 😉 I’ll let you know what happens. Cheers guys.
    miner29er
    Got myself a pair of the 2012 M780’s. Christened ’em today at Llandegla and they were SQUEAK-FREE. Result! Thanks everyone.
The topic ‘XT V-brakes’ is closed to new replies.
