Home Forums Chat Forum Worcester boiler broken remote thermostat, how to override
Viewing 4 posts - 1 through 4 (of 4 total)
  • Worcester boiler broken remote thermostat, how to override
  • mrmo
    New house has a Worcester greenstar boiler and is fitted with
    https://www.plumbnation.co.uk/drayton-lp10rf-single-channel-programmer-digistat3rf-wireless-room-thermostat-275-14979?utm_source=organic&utm_medium=shoppingfeed&utm_campaign=googlebase&gclid=CjwKCAjw-KipBhBtEiwAWjgwrJEvs9YA159Xnt93uKH5EfIlKO8R9c_Vw1sXbnoENr3DqS6zEO1GVxoCpVAQAvD_BwE
    I think,
    Issue Is the remote thermostat is broken, so does anyone know if there is a way to manually force the heating to come on?
    I have someone coming out late next week to replace the part but. it might be nice to have heating during the next week before they arrive
    argee
    Have you searched for the manual of your model and search for emergency mode within the PDF, that should provide a way of manually activating the boiler
    mattyfez
    My wireless thermostat has like a reciver/control box inline with the power suply to the boiler, that you can switch to manual without the remote thermostat, or re-sync wireless contact with the remote thermostat…do you have anything like that?
    thermo
    hot_fiat
    Assuming the thermostat isn’t talking over Bosch’s proprietary control protocol then on the boiler PCB there will be a feed in from the thermostat.  You simply need to bridge this connection.  Check the installation instructions for nest, Netatmo, tado systems as they usually have directions to remove this jumper if no stat was in place.
    You could try bridging on the stat too.
    Beware it might be 240v!
