Home Forums Bike Forum Why does no-one build a cable pull , hydraulic piston caliper?
Viewing 2 posts - 41 through 42 (of 42 total)
  • Why does no-one build a cable pull , hydraulic piston caliper?
  • aracer
    You could feasibly use more braking power on the road than off – as you get better grip on tarmac than on gravel.
    Only if you have so little grip off-road that you can't endo. If you grab a handful of brake on road the front wheel will lock but not skid even with puny caliper brakes and skinny tyres.
    JoeNation
The topic ‘Why does no-one build a cable pull , hydraulic piston caliper?’ is closed to new replies.
