Home Forums Bike Forum What Ti Road bike
  • This topic has 53 replies, 40 voices, and was last updated 1 year ago by Aidy.
Viewing 14 posts - 41 through 54 (of 54 total)
  • What Ti Road bike
  • IvanDobski
    dc1988
    Has anyone ever had a custom frame from Waltly?
    Having had a ride on a PX Hurricane (made by Waltly), it rides so nicely and is beautifully made and really really good value when it’s on sale. The only reason I haven’t bought one already is that they don’t make them large enough for me
    I have, great company to deal with and the product more than met expectations.
    And they emailed me during Covid lockdown 1 to make sure I was ok which was a nice touch.
    mattsccm
    Had a Planet X/On One Pickenflick as my road bike since early 2014. I think it is great. This early the tyre clearance is a bit limiting for knobblies but with 30mm tyres it is fine. No idea who made it.
    HansRey
    I’ve got a colibri ti, as my road bike. I considered getting another as a winter bike, I like it that much.
    Sonder have been good to deal with so far. My next bike will probably be from them.
    MoreCashThanDash
    Completely forgot, but a mate has a Colina – no, I’d never heard of them either, but based in the Hope Valley. He really rates it.
    Titanium Road Bikes | Sheffield | UK
    Caher
    PX Tempest here too that I’ve adapted for the road. Hope wheelset, carbon seatpost etc.its my go to bike 3/4 of the year. Only in the summer do I ride the expensive carbon Roady.
    Two years later and it just whirls along. Love it.
    infidel
    I had a Lynskey R270 until I was knocked off it and it got damaged. It was a great bike but max 28c wheels and no UK distributor now. I did alot of searching and wanted a UK frame if possible. That led me to Enigma and I had a custom Echelon made. I love it. Enigma were great to deal with and put up with my (largely unnecessary) minor tweaks! It’ll go up to 35c and is supremely comfortable despite remaining quite racey in feel. We went for a slightly shorter top tube so that I can keep the stem length sensible as I get older and less flexi..
    https://www.instagram.com/p/Che3SCFjME5/?utm_source=ig_web_copy_link
    me bikey
    try again
    1
    scotabroad
    plunked for the enigma etape ultegra…..
    fasthaggis
    👍 A nice uncluttered look.
    How long will you have to wait?
    bjj.andy.w
    jimdubleyou
    @bjj.Andy.w – any idea if you can fit 32s and mudguards on the hurricane?
    Pictures looks like it might be tight if those are 28s
    It’d be tight but doable I’d imagine. I’m running Kinesis Fend Off Road Bike Mudguards that are able to take up to 30mm tyres.
    endoverend
    Only one of the Ti road bikes shown above is ‘nice’, all of the others have disc brakes… which aren’t needed on the road and make a Ti framed bike weigh near 20lbs. IMO. YMMV and all that.
    Yeah I get what you’re saying. I much prefer the look of a rim braked roadbike and after nearly 500miles on the Hurricane in all weathers I don’t think the discs are a game changer. The only reason I moved over to discs was I was destroying a set of rims every winter (I do a lot of miles in hilly Lancashire) I’m hoping my disc wheelset should last much longer.
    Daffy
    endoverend
    That’s utter bobbins.
    Having owned 5 Ti road/gravel bikes, 2 Litespeed, 1 Kinesis and 2 Planet X, none of them, even the gravel bikes have been over 18lbs and only 1 of them had rim brakes.
    My current Litespeed with 40mm tyres and Di2 is 17.4lbs in a large frame size.
    Yes, hydraulics are heavier, but they allow for bigger tyres and also lighter rims. My current 30mm deep 30mm wide rims are only 320g.
    Vortexracing
    Enigma Echo owner here as well, had it since 2016, its been faultless, comfy and TBH I can’t see myself changing it.
    irc
    I’m not in the market for a £2.5k bike but still drooling over tha Spa. Like the tyre clearance and wide choice of gearing.
    Talking weights my current winter bike for local use is a Spa Steel tourer. I weighed it last week in ready to ride mode with mudguards, rear rack, one small pannier, lock, pump, toolkit, lights, and bell.
    17.1kg. Though that is now down 500g after I switched from a suspension seat post (fitted when I was having back problems) to a normal post.
    dovebiker
    Yes, a couple of mine are on the Waltly site – fatbike and 29+. Very easy to deal with in comparison to XACD who I’ve also bought from and the quality of work is better / less workmanlike. Not sure they’re doing one-off custom frames anymore – only for existing customers.
    Aidy
    They’re not *needed*, but they do brake more consistently in the wet, brake significantly better if you have carbon rims, save rim wear on expensive wheels, allow you to run bigger tyres, don’t overheat rims on long descents, don’t collect as much crud in winter, play a lot more nicely with mudguards…
