Wear your helmet ki...
[Closed] Wear your helmet kids!
88 Users
Had a small off over the bars yesterday on a double step down and landed somehow on the back of my head followed by my R/H side back. I think it's fair to say that my helmet, a relatively cheap Specialized Tactic, did exactly what it's meant to and saved me quite an injury judging by the split in the back!
As an aside what do you reckon to my bruise, 24hrs on?
Posted : 26/07/2010 9:06 pm
Where's TJ when you need his "facts"?
Posted : 26/07/2010 9:10 pm
A bit of superglue will fix that right up for you!
Posted : 26/07/2010 9:13 pm
Has anyone on here ever claimed on Specialized' helmet replacement, are they going to want to see a receipt do you think?
Posted : 26/07/2010 9:16 pm
Just pulling up a chair to this thread as I'm also interested in Specialized's replacement policy. I landed on my head last week and cracked a Deviant full-facer (very stupid school-boy error).
Posted : 26/07/2010 9:27 pm
 juan
LOL at CFH
Helmets? Useless. There's no way my skull would have cracked that badly.
Posted : 26/07/2010 9:29 pm
I'd hold off on spending on a new hat
You just wait until the results of the rotational forces kick in - you'll wake up dead one morning
Posted : 26/07/2010 9:31 pm
 piha
Judging by the shape of the bruise on your back it looks like you landed on a small kiwi-type bird! 😆
Posted : 26/07/2010 9:36 pm
Bit of gaffer tape and that will be fine.
Wasn't as soft as a kiwi, might have been a quail!
Posted : 26/07/2010 9:54 pm
Spesh just need proof of purchase and a cheque for the value of the new helmet sending to their head office. They basically do you a cheap upgrade that's the way the crash replacement policy works. . . . .looks like you we're one lucky boy. Good effort though, 10/10 for breakage.
Posted : 26/07/2010 10:12 pm
Guys - I know you are baiting me but...........
that helmet has failed - it provided little protection. A helmet that has worked has crushed not split
Rotational forces from helmets are real and proven experimentally as shown by the TRL amongst others.
Don't be sheep -be sceptical and look for proof. Follow the science
Posted : 26/07/2010 10:22 pm
Simwit, off you go, you need to re-create the same crash with no lid on and come back and tell us the outcome (or not come back) 🙂
Posted : 26/07/2010 11:09 pm
I've never worn a helmet for high speed crashes ( where those rotational forces might start to play a part), but for this type of low speed impact. My worst crashes have been at less than 10mph and resulted in ( on different occasions) a fractured pelvis, a fractured shoulder and fractured ribs. These low speed smack-downs are where helmets really come into play.
I'm also really interested in the fact that the extra coverage at the back of the head touted by mtb helmets isn't just a fashion affection after all...
Posted : 26/07/2010 11:29 pm
Sorry but STW has taught me that although you may believe you are OK, you will at some point wake up dead and it's your helmet that will have done it. At present it is only specialized's helmet marketing hype that is keeping you alive, where do I send the flowers?
Posted : 26/07/2010 11:42 pm
I'm quite interested in what type of polystyrene crushes rather than splits or cracks. Oh, here's some [i]scientific[/i] facts.
1/ My first helmet, cracked when i landed hard after a bad crash
2/My second helmet also cracked after i crashed and
3/ guess what, my own science proved that my 3rd helemt also split after craching hard.
Now 2 of these were specialized and 1 was a giro. I think my own science has proved that a cracked helmet has done its job properly.
Beats men in white coats in a lab i bet as well.
Also, his 'non protected' back looks worse off than his 'failed, but protected' head i bet
Posted : 27/07/2010 12:20 am
TandemJeremy
Can you provide a reference for that you old waffler? If the helmet has absorbed and dissipated some of the energy rather than the skull, then it has worked.
Posted : 27/07/2010 4:23 am
Tootall - plenty but it won't be believed on here. I will be mocked for even suggesting it and the cyclehelmets.org site will be mocked
People have the is evangelical belief in helmets - and a broken helmet is taken as proof of it preventing injury. They simply are not that good. If the helemt is cracked without being crushed then it has failed and not absorbed much energy
Helmets designed to handle major crash energy generally contain a layer of crushable foam. When you crash and hit a hard surface, the foam part of a helmet crushes, controlling the crash energy and extending your head's stopping time by about six thousandths of a second (6 ms) to reduce the peak impact to the brain. Rotational forces and internal strains are likely to be reduced by the crushing.
http://www.bhsi.org/general.htm
But my helmet broke - isn't that proof?
A helmet is a fragile piece of equipment. On seeing a damaged one, it is easy to assume that a serious injury has been prevented. Cycle helmets split very readily, and often at forces much lower than those that would lead to serious head injury. Helmets work by absorbing impact energy through the crushing of an expanded polystyrene liner. Once compressed the liner stays compressed. It does not bounce back to its original form like reusable helmets for some other activities. If a helmet splits before the liner has partially or fully compressed - and this is often the case - then it has simply failed. It will not have provided the designed protection and may in fact have absorbed very little energy at all.
http://www.cyclehelmets.org/1019.html
Posted : 27/07/2010 4:35 am
I wrote off 2 spesh helmets (along time ago though) first one was a compression complete with a small split ride up the middle from the back where I hit my head. 2nd one was compression only on the front right from a faceplant. Had a bit of a headache both times but that was all. Sent them both back with a fiver (that was what it said in the policy at the time) and received an upgrade helmet in return
Posted : 27/07/2010 5:23 am
 hora
The one time I needed a helmet I wore it. Sheet ice on my road I washed out sideways and I was still holding the bars on the floor.
Posted : 27/07/2010 5:26 am
 piha
@ TamdemJeremy
I was present when Simwit had his tumble and I don't need to read any websites, test results or tea leaves to realise that the helmet saved him from a head injury. As you say the helmet has "failed" because it has split but the helmet has nevertheless prevented a head injury and that has to be a good thing.
The ground where the incident occurred had exposed rocks on it and one/some of those rocks impacted with Simwit's helmet. The helmet received the impact from the rocks and this helmet has the marks to prove this (although the photo's don't show this too clearly). If he had not been wearing the helmet the rocky ground would have impacted directly with his skull and caused injury.
As Simwit says - Wear your helmet kids.
Posted : 27/07/2010 5:27 am
 hora
piha +1
Posted : 27/07/2010 5:31 am
I am a bit confused here which would be the safest helmet then
the Mullet style which covers the head closely or the interlaced polystyrene things which sit on top .
ref rotational injuries they look to have more leverage to cause neck problems
Posted : 27/07/2010 5:49 am
Trout - http://www.bhsi.org/ideal.htm
The crucial things are fit, smooth outer shell and plenty of EPS
Rotational injuries are not just neck injuries but a type of brain injury called diffuse axon injury
Piha - read the second link I gave.
Posted : 27/07/2010 5:56 am
Ouch! That looks sore...
As far as helmet breaking goes, I'm no expert but I was under the impression that although compression of the helmet would result in more of the energy being dissipated surely the cracking of the helmet is going to have an effect? And just the fact it has a hard shell means its going to offer protection. Might not prevent your brain being thrown around in your skull and what not but anything that puts a barrier between head and potentially sharp, pointy rocks has got to be a good thing right?
Posted : 27/07/2010 6:17 am
 piha
TandemJeremy- Thanks for that but I don't have time to read all the info at the moment but will read it when I get time. What I would say is the the link [i]looks[/i] like it get much of its information from RTA records and police reports of RTA. This does not reflect the tumble Simwit had.
Can you find a link that supports your view that is mountain biking specific?
Posted : 27/07/2010 6:18 am
becky -thats about right I believe
piha - unfortunately there is virtually no research about MTBs and helmets. A big gap in the evidence
Posted : 27/07/2010 6:22 am
The three lads I saw on sunday afternoon could do with reading this, nice shiny bikes and camelbaks etc and not one of them wearing a helmet as they headed off into the woods!! Still amazes me!!
Posted : 27/07/2010 6:23 am
Anyone know what giros crash replacement policy is in the uk? Doesn't seem to say on their site
Posted : 27/07/2010 6:25 am
Analogue Andy cheers for the offer but I'm a bit sore/stiff at the moment, do you think it can wait 'til next week 😆
Like Piha says there were exposed rocks where I fell & the evidence of where one impacted is on the helmet so I have no doubt that it did what it's meant to and protected my head from serious injury. Wether it should have cracked or crushed is neither here nor there AFAIC
Posted : 27/07/2010 6:30 am
Astounding! An opinion based on no fact whatsoever.
Posted : 27/07/2010 6:36 am
flatfish - but there is loads of research about how helmets work in general and what I said above is based on the science and the evidence
Posted : 27/07/2010 6:39 am
TandemJeremy - Member
which bascially says if you're going extremely fast and crash into a lamppost or car you may still die. if you're going more slowly and crash, your helmet may well mean you don't injure yourself. the world waits for the next astonishing update!
Posted : 27/07/2010 6:40 am
It says a lot more than that flatboy including some discussion on how helmets work. Still - as I predicted above I will be mocked for following the evidence
Posted : 27/07/2010 6:43 am
but what you don't grasp is the evidence such as that in this very thread. there is a real person with a real helmet. he had a crash that caused the illustrated damage to his back. his head was unscathed while his helmet broke. with me so far?
Posted : 27/07/2010 6:45 am
flatboy - anecdote is not evidence, you don't know what would have happened without the helmet, from my reading of the evidence about helmets that one has failed in such a way it could not possibly have absorbed much energy therefore it did not prevent a serious injury. It probably prevented minor cuts and bruises but if there had been enough energy in the impact to have caused major injury without the helmet the still would have been major injury with the helmet as that one cannot have absorbed much energy
Posted : 27/07/2010 6:47 am
Although helmets are designed to compress on impact, this is in specific conditions on a flat surface. The majority of mtb impacts (and maybe road impacts) will be point impacts. This is more likely to cause cracking (source-wild speculation) and therefore absorbing the impact.
Posted : 27/07/2010 6:50 am
Well I KNOW that my helmet has stopped me gouging big chunks of flesh out of my scalp (over hanging branches) and prevent gashes when I have fallen. I am well aware going 30mph on a descent and coming off it WILL hurt and I MAY even break sommink bad and WILL not pr0tect my neck 🙄
Posted : 27/07/2010 6:51 am
 piha
TandemJeremy - The evidence is that Simwits helmet stopped the rocky ground from impacting with skin and bone. I don't think that cannot be denied.
Posted : 27/07/2010 6:52 am
maybe not in isolation, but given the choice between a swathe of ancedotal evidence - as offered by many many people on here including myself - and none at all - as offered by you - i know where i'd put my money.
Posted : 27/07/2010 6:53 am
Personally I don't care. I'd rather have even the [i]tiniest[/i] bit of energy dissipation than have the lot delivered to my noggin.
Surely the point of helmets is to protect against injury? It might not help if you hit a tree at 30mph or maybe fall off a cliff, but for the majority of us, not visiting casualty for stitching or cleaning of gravel rash is a big plus.
Posted : 27/07/2010 6:54 am
Back to the boring bit about Specialized crash replacement...
Every time I've used it, I've either mailed or phoned their customer services dept and told them roughly what happened and which helmet I'm looking at as a replacement. They have given me a price, and I've sent the old helmet off with a letter and cheque. It usually takes about 2 days to get the replacement on my desk. The last one was a Deviant, and I was offered the option to upgrade to the carbon one at £85.
They did once tell me to use the "crash replacement scheme" because the pads had worn out and they didn't have any left, as it was an old model - I certainly wasn't complaining about that one!
Posted : 27/07/2010 6:56 am
 juan
tj you do know that specialized helmet have succeded in the snell test...
Posted : 27/07/2010 6:57 am
sorry, this case provides no 'evidence'
simwit himself says that he doesn't really know how he ended up landing like he did.
so,
how did he land? (angles and things)
what did he land on? (friction values, shape and size of penetrators)
how much energy was involved?
how much energy was absorbed?
how much ... etc.
what ... etc.
i'm very glad simwit is still alive, and relatively unhurt, and personally i suspect he benefitted from wearing his crash-hat, but there isn't much evidence from this case you could take away and study*. i've no idea how you'd use this case to make a better helmet - that's the kind of thing evidence can do.
(*except maybe, 'had a helmet on, didn't die' - which i suppose is evidence of sorts)
(yes i wear a helmet habitually)
Posted : 27/07/2010 6:59 am
piha - indeed - I don't deny it saved a minor injury - I think that is almost certain. What I doubt is it saved major injury.
Helmets are very good at preventing minor injuries - lacerations and so on.
Flatboy Follow the links I gave to real evidence about helmets. I have read widely on this including reading the various research papers. Cyclehelmets.org is a good source of links to real evidence but do take your pinch of salt with you when you visit it
http://www.cyclehelmets.org/1052.html
Posted : 27/07/2010 7:00 am
TJ, do you actually wear a helmet, and if so, what is it?
The rest of the class: this is not an excuse to post up numerous hilarious pictures of inappropriate headwear...
Posted : 27/07/2010 7:02 am
Isn't fact free trolling fun (for some - but rather tedious for many others) . . .
The images of the helmet are clearly insufficient to determine whether it did or did not crush, being fixated on the crack and the opportunity to troll has blinded the troll to the possibility that the helmet may well have done the job it was designed to and the ultimate failure may be inconsequential or may be a result of it's deformation.
Without a detailed and informed inspection it's not possible to state "that helmet has failed - it provided little protection" . . .
troll on . . .
Posted : 27/07/2010 7:03 am
 LHS
TJ, I know that "discussing" with you is often pointless but what you are stating is complete tosh.
I have worked in the design of helmets for years and have covered a lot of work in impact protection both simulation and testing.
Helmets are designed to collapse in more than one failure mode. One of those failure modes is to break up upon impact to further disperse the energy. From impact testing on various polystyrenes it is evident that the compression of the polystyrene foam is not solely suffcient to reduce the acceleration in an impact to an acceptable level.
 DT78
Does this rotational stuff apply to other sports then? - what about something like motocross? helmets can weigh loads there. Don't see many of those guys riding without them?
That's because they're wearing them to prevent grazing or minor bruising. If there was no chance of that they'd do it nude.
Posted : 27/07/2010 7:06 am
Its a pointless argument as unless you test real people whilst crashing in a laboratory environment (I would guess this would be illegal 😉 ) then you'll never know 🙂
Edit: The problem is you cannot reenact a real crash in exactly the same way i.e. Ive crashed and I'm OK lets crash again without my helmet 😉
Posted : 27/07/2010 7:08 am
 LHS
Fit - Yes
Smooth outer shell - Yes
Plenty of EPS - not necessarily, only up to a certain thickness depending on density.
Instrumented dummies work fine.
Posted : 27/07/2010 7:09 am
 juan
Well your problem TJ and you absolutely refuses to listen to me on that, is your LR is biased. All the article comes from a source that is against wearing a helmet.
What you need to do is forget about everything you've read. Go on ISI web of knowledge and start from scratch.
You need 10-15 article to start with, using appropriate keyword and then do some upstream and downstream research from these papers.
Plus a helmet that split still do his job. Where do you thing the energy responsible from the split came from.
First glad to hear you ok and not seriously hurt.
As for TJ, he is simply saying don't put too much faith in them they may not always stop a serious injury. They are not the the be all and end all just another safety margin in case something does go wrong.
Rotational injures happen in all forms, it's a the same as deceleration injury in theory it could happen by simply running flat out and then stopping suddenly. Of course this is a silly extreme but it's simple physics, stopping a container suddenly means the contents will continue to try to move until the hit something or loose their energy.
Posted : 27/07/2010 7:10 am
foxyrider - Member
Its a pointless argument as unless you test real people whilst crashing in a laboratory environment (I wold guess this would be illegal )
nah, not illegal, you just need them to sign some forms...
(i heard about a phd that involved studying how old people fall over, to study this old people were harnessed up, told to walk across a room, and then someone pushed them over without warning - the harness stopped them hitting the floor, and high-speed cameras recorded the body postition as they fell, i'm a bad person and i thought this was hilarious, wish i'd been there)
Posted : 27/07/2010 7:13 am
Fergusd sums it up for me, we're all "fixated on the crack" - as he so nicely puts it! 😆
Helmets have saved me at least two trips to hospital, thereby saving the NHS money and saving inconvienience to myself and my riding buddies. What's not to like?
Posted : 27/07/2010 7:18 am
TJ, if you could see into the future and knew you were about to have a similar accident to the OP, would you have worn the helmet or gone with no protection?
If it was proven that it only saved the OP from minor injury, would you have worn the helmet?
Posted : 27/07/2010 7:19 am
I'd not ride that day. 😆
Posted : 27/07/2010 7:22 am
 piha
Ahwiles - Interesting post, to be able to collect all the data required to answer your questions accurately would be very difficult. You would have to replicate an identical crash many times to accurately measure all the different forces, speeds, impacts and all the other "how much" & "whats". I doubt that could/would be done. It stopped an injury to the head and that is the important thing.
TandemJeremy - I agree that helmets are very good at preventing [i]lacerations and so on[/i] but how can you be sure the helmet didn't prevent a major injury in Simwits off?
Posted : 27/07/2010 7:24 am
 LHS
Believe me it is done.
Posted : 27/07/2010 7:29 am
ahwiles, I can't supply answers to all your data requests but the surface I landed on was greenstone bedrock with a covering of leaves, twigs, loose sand/gravel and most importantly loose rocks up to golf ball size maybe a bit bigger. Initial contact with the ground was on my head going forwards and over so that I ended up on my back (it all happened a bit quick & I wasn't taking notes so vital info may be missing-sorry) The head impact was enough to knock my vision out of kilter for at least 10 mins so I have no doubt that it would have been hard enough to have caused me quite an injury.
Posted : 27/07/2010 7:30 am
Woah. You went to A&E to get checked out right?
Posted : 27/07/2010 7:37 am
Yep sure did, Piha^^ marched me there! Ended up having an ultrasound to check I hadn't damaged my kidneys or summit because of where the impact on my back was.
Posted : 27/07/2010 7:51 am
Your visual cortex is at the back of your head, hence the problems, mangatank does have a point!
Posted : 27/07/2010 7:53 am
And if helmets are such a devil's spunk, why are they worn by Peaty, Hill, Rossi, Cavendish and many other useless 2-wheel riders?
TJ basing his argument on the irrelevant data, what a surprise 🙄
Posted : 27/07/2010 8:02 am
a. sponsorship deals
b. lessens air resistance
Posted : 27/07/2010 8:16 am
T666Dom - Yes thats correct and would be a coup injury/trauma (allthough mild) but don't forget the contracoup injury 🙂
Posted : 27/07/2010 8:17 am
 Solo
Hhmmm. Helmets...
The cracking of the helmet indicates energy dissapation, energy that would have otherwise had to of been dealt with, by natures protection...
However, upto the point the helmet failed, most of the energy was being passed to the head, imo.
My experience leads me to think that current popular helmet deisgn does not absorb much energy. The polystyrene, as dense as it is, seems to transmit energy to my head quite well.
I was reminded of this recently when for the first time in a long time, my helmet clipped a low branch.
It was still quite an abrupt shock to my head, very little energy had been absorbed by the helmet, there wasn't much [i]cushioning[/i] of the blow and I attribute this to the dense polystyrene and the absence of a more compliant, cushioning, layer of material.
However, the skin had not contacted the branch so I wasn't left with any cuts, etc.
Current helmet design seems to be a compromise to meet several criteria, not all of which may be safety/crash centric.
How many helmet group-tests have we read where the journos refer to "cooling", "airflow", and even asthetic featrues ?
Throw into the mix, manuf costs and its not difficult to see how current helmet design has arrived at where it is now.
I don't think current designs are the best mankind could come up with for the primary purpose of preventing significant head/brain injury.
I think we only need look at helmets from other sports to get an idea of the solution other companies have come up with to try to prevent serious head injury.
Personally I fail to see the difference between a motorcyclist hitting their head against a lamp post at 25mph, and a mountain biker hitting their head against a tree at 25mph.
Yet, the helmet design solutions for each are very different...
But then again, who's going to wear a motorcycle helmet for a quick bit of XC riding ?..... 😉
I'm glad the OP is Ok, and if they think that their helmet prevented a more serious injury, then thats fine.
However, I tend to think that it shouldn't be a question of whether or not to wear a helmet, there is definately a need for head protection.
But rather, which design solution should we be wearing ?.
Cheers.
Solo
Posted : 27/07/2010 8:22 am
On couple of occasions I witnessed that a helmet comes useful. Riding with my mate in the Pentlands, his wheel got jammed and went OTB, Giro E2 cracked and after further inspection there was also a 1" deep dent in the helmet that would be in his head otherwise.
Mate was riding round a tree while i was setting my bike up. Somehow he lost the balance and hit his head on the tree, helmet shell had a small dent after. His face would probably be worse off without a helmet.
Riding with my mate on road, he has flat pedals and a pisspot helmet. Somehow his leg slipped off the pedal and he landed on the road, his head just bounced on the road, he said he could feel the impact and it would probably end really bad if he was riding without his helmet.
Again in the Pentlands. My mate fell into a stream at low speed. Straight on his face, Spesh Propero saved his forehead as the helmet took most of the impact and he only had a black eye after that.
However my GF's brother was riding along and didn't duck under a branch that caught on his peak and ripped it off the helmet slightly suffocating him for a second or two with the helmet straps 😉
TJ Your helmet cracked when You were on Your way to a TBC evening ride 🙂
Whatever the evidence is out there I just prefer to wear my helmet, it's light, well ventilated and look ok. It's not obligatory to wear a helmet and I choose to wear it. Simple as.
Glad the OP is ok. If anyone prefers not wear it than it's their choice and I won't be trying to convince them.
Posted : 27/07/2010 8:23 am
TandemJeremy
I read your link. The 'Ten Principles' is quite a splendid piece of academic suggestion ie it works, in a vacuum. If someone presented those points as the 10 Key User Requirements and asked someone to build it, they wouldn't get very far. In the real world, most things are a compromise (insert Bontrager quote here) as the desired item is unattainable.
Materials are designed to work to parameters so they can be used in the real world. The 'failure' as you see it is just the point at which compression is no longer possible. A crack still dissipates energy - this is normal and designed in to many things like vehicle armour etc. You are using science to argue your point - it may not be bad science, but it isn't always the most suitable, accurate or 'real world'.
Solo - compromise - you can't have everything as it just won't work in the real world. See the 10 points in the link above.
Posted : 27/07/2010 8:29 am
[i]And if helmets are such a devil's spunk, why are they worn by Peaty, Hill, Rossi, Cavendish and many other useless 2-wheel riders?[/i]
Because they have to?
Check out the TDF just a few years back before they weren't compelled to 🙂
Posted : 27/07/2010 8:30 am
Look at the way the head impacts the ground in this video. Classic MTB spill:
Posted : 27/07/2010 8:31 am
@ Mieszko.
I'm sorry but I couldn't help but laugh at the incident where rider was basically clothes lined with his own helmet!!
Posted : 27/07/2010 8:37 am
Another classic here
[url]
Posted : 27/07/2010 8:39 am
Well for one the reason your question poses. If they didn't sheep would follow them and say shit like 'well peaty doesn't wear one'.
Posted : 27/07/2010 8:40 am
 Solo
[i]A crack still dissipates energy - this is normal and designed in to many things like vehicle armour etc[/i]
Yes, to crack the Mat'l, energy has been "used", but once the crack occurs, all protection is gone. So I wouldn't describe this as a great feature.
What about secondary impacts ?...
As for vehicles. Vehicles crush, commonly referred to as "crumple zones".
But thats just the body.
For the soft squishy occupants ?, they get belts and bags. Modern belts tension, but still have a release point if forces become too high, and the bags are designed to deflate, they are "vented" to provide a cushioning effect, to decellerate the head rather than bring it to an abrupt stop.
In other words, forces are controlled and decelleration beneath a certain threshold, is the goal.
Current helmets I've seen/I own, are dense polystyrene, and something as round and blunt as my head isn't going to compress it enough to enjoy any cushioning effect during an impact.
When my head hits the imoveable object, decelleration rises rapidly, forces increase then at a certain point the helmet mat'l fails in an instant.
In that situation, its been my head Vs the polystyrene, until the polystyrene gives up.
However, if you're going to sell helmets for £8, then I suppose the current design is all one could reasonably expect. And its at that point that one then considers whether a poor design of helmet is better than no helmet at all.
FWIW, I wear one most of the time, but could they be better ?, I think so.
Are the current designs better than no helmet at all ?.....well, thats a difficult question for me to answer.
So, anyone up for £250 cycle helmets ?.
S
Posted : 27/07/2010 8:51 am
But rather, which design solution should we be wearing?
I think Solo has it right. Most helmets are tweaked road or actual road designs. This make sense because of the physical effort involved in cycling, and if anything overheating is more of an issue in MTBing, making Road helmets an even more attractive proposition. Their ability to prevent cuts and laserations is excellent. Their ability to absorb impacts is clearly limited.
It's hard to see a good alternative solution that wouldn't be unbearable to wear. Much like almost all forms of bike armour in fact.
Posted : 27/07/2010 8:52 am
It is my completely unscientific view that anyone who doesnt wear a helmet whilst riding off road is a ****.
Theres lots of cool things about helmets.
Posted : 27/07/2010 8:59 am
Page 1 / 5
