Home Forums Bike Forum Wahoo GPS Riser?
Viewing 5 posts - 1 through 5 (of 5 total)
  • Wahoo GPS Riser?
  • dirtyrider
    I’ve got a wahoo roam, but I want to use it for some longer rides, I cannot connect a usb cable as the wahoo sits too close to my bars, it’s run on a custom mount from raceware, ideally I could do with something to sort of stack the wahoo up temporarily for longer rides, anyone know of anything?
    whatgoesup
    Could you use conventional bar mount? (the type that zip ties to the bars or stem) – I think one comes supplied with the head unit in addition to the out front mount.
    bliking
    How long are your longer rides? Battery life on my roam is easily good enough for 12 plus hours of recording and navigating.
    Anything longer I’ve topped up charge using a battery pack when I stop for food.
    tonyd
    Why don’t you drop a note to the folks at Raceware? Maybe they can 3D print you a shim.
    ballsofcottonwool
    stack of 2 quarter turn Garmin to Wahoo adapters?
The topic ‘Wahoo GPS Riser?’ is closed to new replies.
