Home Forums Bike Forum Tubeless valves – hewn from unicorn horn or just over-priced?
Viewing 35 posts - 1 through 35 (of 35 total)
  • Tubeless valves – hewn from unicorn horn or just over-priced?
  • Stoner
    Why oh why oh why are tubeless valves so expensive?
    £10 for a pair of valves? Bloody outrageous price!
    Im going to have to attack some old innertubes and salvage the valves. I reckon customising the rim well seats using some Sugru might be a smart idea too.
    Yours faithfully,
    Tunbridge Wells
    jimdubleyou
    On a related note – anybody know where I can get a replacement o-ring for valve*?
    * I lost one when I had to put a tube in last week…
    Stoner
    I can get you one.
    Cost you a tenner though.
    garage-dweller
    Jim Do you mean the little rubber ones that go over mavic type valves and then you do lock nut up on top of?
    PJM1974
    £10 for a pair sounds reasonable in the grand scheme of things. There’s an outfit who’ll relieve you of £55 for a front mudguard because the word “Enduro” is printed on it. That’s not the zeitgeist of Peak Arsehole, but it’s well worth bringing up, repeatedly.
    Alternatively, you can buy a presta tube from your local supermarket, take a pair of scissors to it and the job is done.
    Stoner
    quite.
    Ive never understood the need for removable cores – I just pop the bead off for a few inches.
    The only other advantage is the fat conical rubber rim-well seat which does tend to seal a little better than the left over inner tube rubber on the bottom of el cheapo valve.
    Beagleboy
    Think I recently paid £8 each for my tubeless valves from the bike shop in Glasgow that’s local to my lab. I just thought that was the going price. 🙁 .I’d jump at a tenner for a pair. :-/
    Garry_Lager
    Recycled inner tube valve will work reliably, may need a bit of bodgemanship to get it seated on some rims, but then you’re set.
    I buy the proper ones if it’s a shiny new set of wheels just because, but there’s really no need.
    jimdubleyou
    Aye, that’s the ones.
    I’m a tubeless newbie so not sure if it’s really needed or not!
    Kahurangi
    Cut them from old inner tubes – I have a handful of wheels done this way. If you do the nut up quite tight (as you may have to depending on the rim bed) it’ll eventually tear the rubber off.
    Removable cores on tubes exist only so that if you use a Lezyne screw-on style pump you will unscrew the valve core instead of the tube, leaving you with a deflated tube and a valve core somewhere across the busy road 🙁
    Stoner
    BB, here, take my seed. Have my babies.
    This is what love looks like.
    I withdraw my munificence. It’s still £9 posted for 2. 🙁
    Kamakazie
    Cheaper from Evans if you’ve got a store nearby.
    The removable cores are good for seating tricky tyres without resorting to soaping up / a compressor.
    All my tyres have gone up without faff when the valve core has been removed. Not so with it in there.
    Kryton57
    Stoner – Member
    Tunbridge Wells
    You can afford it.
    freeganbikefascist
    ^I’m going to make a habit of using that
    10 for a pair sounds ok, tbh. I recall being asked > 20 way back when, which did irritate me
    What’s a schwalbe inner tube cost these days? Probably a fiver so you wouldn’t save much/anything. You could farm them from old tubes and call that free I guess but if they were cheapos to begin with then they probably don’t have removable cores
    PrinceJohn
    I find the removable cores helps blast enough air into the tyre quickly enough to get tricky to seat tyres seated
    lees
    “What’s a schwalbe inner tube cost these days? Probably a fiver so you wouldn’t save much/anything. You could farm them from old tubes and call that free I guess but if they were cheapos to begin with then they probably don’t have removable cores”
    What he said…..
    dantsw13
    My Vavert tubes from PX come with removeable cores for a couple of quid. Trim them carefully and smoothly for maximum faff-freeness.
    flamejob
    _mild hijack
    Am I to assume that one of the major disadvantages of Tubeless is that swapping tyres (park weekend to trail riding weekend) is one of the biggest PITA?
    james
    £3 each posted? Specialized with removable cores
    Granted you may have to trim the square bases for some rims to get the tyre into the well pre-seating
    Still, cheapest I’ve seen and the valve heads themselves don’t seize like some can
    whitestone
    If you are changing tyres that often then it might be better to have two sets of wheels.
    Once you’ve got a tyre to seat tubeless then refitting tends not to be too bad, the biggest pain is getting the sealant out and even with the best system you are going to lose some sealant each time you swap so it’s not a no-cost operation.
    Let tyre down.
    Remove tyre leaving sealant in bottom of tyre for moment
    Put new tyre on but leave one side off so you can pour in sealant from old tyre.
    Scoop sealant from old tyre to new.
    Seat second bead
    Inflate.
    Northwind
    jimdubleyou – Member
    Not needed- the only actual seal is the one between the base of the valve and the inside of the rim. There’s no point sealing up the outside of the rim (where the valve sticks out) because the rim itself should never be pressurised anyway. It’s a mystery why some valves have it tbh.
    bigblackshed
    Kryton57 – Member
    Stoner – Member
    Tunbridge Wells
    You can afford it.[/quote]
    Le Chateau Du Stoner makes Tunbridge Wells look like a third world slum.
    Stoner, just buy some decent tubeless valves you tightarse. 😉
    (Yes, we are getting ripped off).
    Stoner
    I didnt become the immensely wealthy oligarch that I am today by being lavish when it comes to mountain biking. Afterall, I own a number of On-Ones… 😀
    leftyboy
    Main reason I use removable cores is to avoid repeatedly* reseating tyres and risking damage to the bead.
    * probably only 2 -4 times a year so repeatedly might be a bit misleading 🙂
    timbur
    Tunbridge Wells darling? That’s just up the road.
    Worrying.
    flamejob
    Mmmm… thought so.
    I haven’t done any of our non-fat bikes.
    I did come up with an innovative solution to bead seating though…
    nickc
    yeah but…
    It’s a a tenner, you know it will work first time, and will just sit there doing it’s job tyre change after tyre change after (you get the idea). Bodged might go up, might not, who knows, might stay up over night probably won’t though so you’ll have to faff with it…again.
    bm0p700f
    They cost a tenner because they are £5 and bit trade. Take out VAT, postage and there is not a whole lot left for the retailer. They are tenner because the manufacturer has to make something, the distributor has to make something and then the shop has too. If you want the cheaper set up a bike shop and buy them trade.
    Speshpaul
    why are the more expensive than a tube then?
    Not that I’ve ever paid for one, always cut them from an old tube.
    simons_nicolai-uk
    My tubeless valves have all “failed” when the cores got bunged up with sealant. Quite a few of my old pile of “to be repaired” inner tides have removable cores which fit the tubeless valve stems.
    Stoner
    I assure you I am fully conversant in the dark ways of capitalism, and even concede that the tubeless valve market is going to be limited so unit prices will be higher, but even so, I was surprised there wasnt a raft of budding Chinese price gougers on eBay banging them out for 50p each.
    lightman
    This is why you should be friendly with your LBS, my mate has a shop and usually replaces a few tubes a day, so is cutting the valves off for me 🙂
    DoctorRad
    Why not just nick the valves off old Schrader tubes and take the cores out when seating? Or are all tubeless ready rims presta only?
    You’re right, I’ve never run tubeless, but I’m curious…
The topic ‘Tubeless valves – hewn from unicorn horn or just over-priced?’ is closed to new replies.
