Sealant loses its effectiveness in a variety of ways depending on brand/composition over time. Stans is particularly famous for turning into ‘stanimals’ (stringy solid mess of latex) inside the tyre – although certainly the first application is mostly going to coat the inside of the tyre anyway.
Generally in the UK Stans’ will probably need replacing every 6 months or so although I’ve have tyres with it happily last well over a year without being disturbed. In Southern California, apparently 6 weeks or so is typical. Given the temperatures recently I’d go with that. Pressures will naturally change with temperature anyway. If the bike has only been ridden once since setup it may not even be fully sealed yet. These things can take a little time to bed in. If in doubt, take a wheel off and shake it by your ear. If there’s sloshing, you’re good. If there’s no sloshing you can hear, then while you may be sealed you’re not going to survive a puncture so you may want to pop the valve core and add some goop.
‘Orange Seal’ sealant’s claims to fame were that it could survive slightly bigger punctures than Stans and that it lasted longer – IIRC it’s rated for about 3 months in So Cal.
