Wind the L limit screw in a touch more prior to clamping, and you will get a bit more cable tension.
I take the it the convertor is the right way around?
Also the first time I clamp it I will hold the mech and shift to settle the cable ends (assuming internal gear cable, if its external just pull on an exposed section of inner as normal)(you will normally get quite a bit of “cable stretch” as the outer seats in the cable ends/compresses slightly)
The washer can also rotate when you tighten the bolt which slackens the cable, a drop of oil or grease between the bolt head and washer can sometimes help with that, if not just wind the L limit screw in so the outer plate is further out than the big ring.
