woohoo, 85%. In. Your. Face. Electricikery!
*vvvzzztttttt*
oofarrggyerbastard!
Shoddy icing? I was going for the “Volcano” effect. And as for glace cherries, it has been Jr tested and deemed acceptable.
toys19/mcm – post spikes work fine there. I prepared that gravel area a couple of years ago with 8″ of hardcore. Over that is a weed membrane and then I put ground guard interlocking plastic plates before filling with gravel. To prepare the ground today, I had to cut away a small portion of the ground guards. The spikes are driven through the hardcore so that the base of the post box sits flat on the hardcore. It’s not going anywhere. Not to mention the total weight of the shed being supported by 7 contacts points probably amounts to no more than 7lbs/in.
It will be clad mcmoonter, but Ive borne in mind your earlier posts on airflow and going for a “now you see it, now you dont” style clad. i.e. each bay between uprights gets an alternating featheredge board on the inside then outside. The posts are 4″ square so there’s plenty of airflow while still retaining the logs without having to do the whole wall building with logs thing.
When I built the woodstore (more a pole barn really) down the other end of the field, that is on Keuper Marl – basically a mud clay that just goes down all the way to Hades. So for the posts there I have to dig out a big hole, set the post and then fill with concrete. Its not like it’s taking much weight though, but the main reason to do it is that clay heaves and shrinks through the seasons so to stop the posts becoming loose its a good idea to have a large surface area for your pile.
toys19 – as I see it you have 3 different ways of supporting your shed contents:
1) on a suspended floor hung on your posts
2) on a frame floor that sits directly on slab bearers
3) on a filled floor a la footflaps
for 1) then yes you will need to look at providing decent post bearing if you dont have a bedrock like mcmoonter. Read up on post foundations with back fill.
for 2) you may the ground good with hardcore and maybe a thin layer of sharp sand or even dry mortar mix on to which you set and level concrete slabs over a sufficient area that your shed base can rest, and your shed walls then can either be attached to posts or to the base itself.
for 3) call wrightyson, he loves his concrete 🙂
