Home Forums Chat Forum The Solar Thread
  • This topic has 1,448 replies, 138 voices, and was last updated 2 weeks ago by Daffy.
Viewing 40 posts - 281 through 320 (of 1,450 total)
  • The Solar Thread
  • TheBrick
    MCs (total racket)
    Like most of these schemes they binfit the scheme providers and the larger companies to increase barriers to entry.
    surfer
    The vast majority of the time you’ll be getting less than 3.6kw off the array anyway, and when it does go above this it’ll be on a sunny day when you’ll generate more than you can use anyway.
    Agree although its important to do all the calcs yourself they are quite unique to each household. We have a 5.6kW PV and an 8.7kW battery on order. Wife works from home and I am retired so around most of the day. Intend to use as much as we need during the day then once battery topped up send the rest to our Immersion tank via an iBoost solar diverter. Any spare after that goes to the grid until we get an EV then into our Zappi as our EV will mainly be on the drive. We are with Octopus already so intend to go to their overnight tariff and top up the battery during the cheaper hours.
    Waiting for our survey and to ask questions as to how configurable all of this is and how the separate components work with each other.
    trail_rat
    Just remember the bigger the inverter the bigger the start up current required from the panels.
    I went from an old gen 3.6 to a current gen hybrid and I generate at much lower light level.
    st66
    I’ve just been going through the calculations for potentially getting solar panels for our house. It seems to me that the recommended size of system recommended for a typical 3 bed house (3-4 kW) are flawed and based on typical energy use for an entire day. However, unless you are storing excess energy with batteries (expensive) or using it to charge an EV for example, then the most efficient thing to do would be to size the system based on how much energy you typically use per hour during sunshine hours. Any excess that you generate from an oversized system gets very little back from feed in tariffs compared with what you save on actual usage (and obviously costs lots more to install).
    We use approx 10-12kWh per day – so ~0.5KW per hour. It seems like a ~1kW solar array (producing 1kW energy per hour) would be more than enough to directly provide the power that I would need to run appliances during the day.
    Or am I missing something?
    surfer
    You are right in terms of your daily usage apportioned evenly through the day but when you use power 1kW is unlikely to be enough. Many appliance use more than that, Toaster/Dishwasher/Washing machine etc so you are likely to be using your 12kW per in day in bursts. If you go over the 1kW then at that point you will be drawing from the grid unless you have a battery that can deal with the surge.
    trail_rat
    If you size panels to your use. Your reliant on the panels producing max all day long.
    Need redundancy.
    I have a 4kw array and even on the dullest of days I cover my static demand and only pay for my active use.
    When it’s bright the batteries get charged. And allow me to run the power heavy things free. Previously the panels only ever subsidised and it was impossible to use 100% of power generated without using more electric than intended.
    bruneep
    Good luck with that thought process, what are you going to do when sun doesn’t shine or at night?
    5.3 array and 2 x 5kwh batteries, even on good days spikes in demand, electric shower oven etc mean we draw from grid,.
    st66
    My washing machine uses ~0.5kWh per cycle (as does the dishwasher), so if I used these only during the day, they might be mostly covered by the solar energy generation (from a ~1kW system), I understand that peak energy consumption for the washing machine might be 2000watts, so this would need to draw from the grid.
    As you say, a bigger system would produce more background generation on less than ideal days, but would cost a lot more to install, and the payback would take longer. Just trying to understand what we might need – I’m not prepared to pay the extra for battery, but can see that this is the answer to the problem of excess energy production.
    trail_rat
    Cost is largely access and labour.
    1 inverter costs x
    Purchase of 1 panel is 200 quid . 10 panels is 2000 . But your inverter /labour and access on either system is 3 or 4 grand
    As a proportion of the install adding more panels is not massive given the cost of the rest of the kit given the benifits it brings and over its lifetime
    st66
    Also, most of our energy use must come in the evening (electric oven, tv, Kids xbox, lights etc) when the solar energy generation isn’t optimal, so my estimate of 0.5Kw per hour during the day is probably on the high side (except when washing machine or dishwasher are on).
    trail_rat
    That’s why batteries although pricy make so much sense…
    flicker
    I’ll not repeat what others have said, but you’ll be VERY disappointed if you go ahead and have a 1kW system installed (3 panels, you’re wasting your time and money). The 1kW is the theoretical maximum, it will never generate that even when conditions are perfect (best conditions are cold sunny days, efficiency drops off the warmer the weather). Peak generation is when the sun is highest and tails off either side of that.
    With a 4.2kW system the best days of summer we generate 30kWh, best days of winter 6kWh, however last December we generated a measly 52kWh for the whole month, 15 days were below 500Wh.
    Biggest regret with our system? We only had 4.2kW of panels fitted, in hindsight we should have covered the roof, that would have given us a theoretical max of 12kW.
    flicker
    In that case don’t have solar installed unless you’re fitting a battery too to utilise the generation.
    We generate 4000kWh a year and use 35% of that, but that’s because Mrs f is at home all day so the dishwasher, washing machine, oven etc are used during the day to make the most of the energy we generate
    st66
    I suppose I’m trying to justify to myself that a ~1kW system would be useful! The problem for us is that although we have an ideal roof aspect (south facing), it is a shared roof with our upstairs neighbour (flat). This is Edinburgh – so common to have a groundfloor flat (us) and upstairs flat. So my understanding is that we would have to draw up a legal agreement for future maintenance responsibilities and change the deeds to reflect this. Although not impossible, this would add to the expense etc. Our upstairs neighbours are elderly (80+) and don’t want to install solar themselves (they also worry a lot…).
    We do, however, also have a single story extension with a flat roof that could accommodate 3-4 panels (so maybe 1600 watt max with 400w panels). I was just seeing whether this is a good idea with my calculations. Access and installation costs might be lower for the flat roof I guess (although would need some kind of racking)
    sparky1uk
    That said, a larger inverter does give you more headroom to run larger loads from solar on sunny days (not necessarily from the battery – the givenergy battery can only output 2.6kw whatever the inverter), so assuming it’s not that much more expensive you might as well.
    Thanks @phiiiiil , £300 difference for 5k inverter, sounding like a good idea then assuming it’s ok with the DNO. I’ll estimate how often I’d be using more than 3.6kW + max battery discharge rate. If I can get the panels I prefer I might be able to fit 16 panels so 6.48kWp. Time for more PVGIS calcs.
    trail_rat
    Consider if you have multiple roofs – you can extend your solar day for a significant part of the year with east or west or even north (for 3 or 4 months anyway) and that longer solar day is more useful (to me anyway) than peak solar output
    igm
    3.6kW was quoted £7000 including £1000 scaffolding for our house, and 7.3kW £9000 including £1000 scaffolding.
    100% more capacity added 28% to the price.  Though you do need a G99 export agreement.
    Guess what we went for?
    Greybeard
    @sparky1uk    We have a Zappi, it came with a ‘Hub’ which plugs into your router and a ‘Harvi’ which is a small collar that fits round your mains cable and a module that communicates with the Hub and thus to the Zappi. The Harvi measures the power drawn or exported back to the mains. There’s a phone app that links to the Hub on which you can see how much you’re exporting and decide if you want to charge the EV. Our EV requires at least 1.4kW to charge, which I think is standard for EVs. The Zappi has 3 settings, Eco+ which will only charge if there’s at least 1.4kW going spare, and so cuts in and out as clouds pass over, Eco which charges at  the higher of 1.4kW or the amount of spare, or Max which is a flat 7kW. I tend to use Eco, and switch off if the sun goes in. The Zappi works as designed on Eco+, but after the first few cycles of on/off, our EV (a VW) gets fed up with being messed about and stops accepting charge, so it has to be unplugged and plugged in again to reset it. It would be nice to just leave it on Eco+, and hopefully there will be software upgrades that fix the issue.
    Flaperon
    Cold wash, presumably?
    I considered a Zappi but decided that the £900+ installation cost (you also need the Harvi wireless transmitter) would pay for a lot of electricity. With a battery installation and a sunny day, I just limit the car to 10A between 9am-4pm, with unrestricted charging in the cheap overnight period. If a cloud drifts over the panels then the battery picks up the difference and recharges once it brightens up again.
    So far I’ve not troubled the grid during the peak hours, although with an electric hob I would say that I’ve developed a tendency to cook steaks slightly rarer than I used to because you literally watch the battery emptying itself expensively in front of you while cooking.
    sparky1uk
    Thanks for the info @Greybeard. Ours will be a cupra born, based on the ID3 so maybe have the same bug. Do you have a battery on the PV? Sounds like that can add another layer of control/complexity, with export (or charging in my case) directly from solar only after the battery is full.
    Greybeard
    No. We use about half what we generate, on average in summer, and I suspect we’ll use a higher percentage in winter, and at times in summer we’d fill the battery. I calculated payback at about 23 years. I’d rather spend money on more panels, which are an overall environmental benefit. A battery is just a financial benefit to us, it doesn’t do anything for the planet.
    st66
    No, 30C wash but speedy cycle. Measured with a power meter.
    phiiiiil
    Looking at what uses power on the various graphs our system provides, our normal washing machine cycle uses just less then 0.5kwh and the dishwasher just over 1kwh, but both use most of that in a short period when they go up to 2.5kw. It would need a fairly large system to be able to provide that on anything but a super sunny day.
    phiiiiil
    Is there a reason why scaffolding seems to vary so much? Quite a lot of houses round here have gained solar panels this year; some have had proper huge scaffolding erections put up, often for extended periods of time, but others – including ours – were done just using a mobile scaffold tower that took no time at all to build and take down and must have been an awful lot cheaper.
    igm
    Not quite true. The battery allows time shifting of demand, meaning that generation resources outside the home as well as inside the home can be better utilised.
    That means that for a given energy use less aggregate nameplate capacity of generation is needed – that is a benefit to the planet, and it is particularly true with variable generation like wind and solar where you harvest the energy into a battery when you can to use when you need it. It is less true in a system with plenty of flexible (we used to call it dispatchable) generation like CCGTs. But hopefully that will change.
    So is a battery an environmental a benefit in isolation? Possibly not. But in aggregate it is. Just let’s not get started on particular battery chemistries and characteristics – that’s where it gets hard.
    st66
    A question about battery capacity and how much can be run from it.
    I understand that Wh = Ah x V, so a 100Ah 12V battery can provide 1200Wh, but what happens when you convert your 12v DC battery power to 240v AC power with an inverter? Do you still only have 1200Wh or is it now Ah x 240v?
    surfer
    Unless you dont consider the harnessing and use of electricity that would otherwise be lost a benefit to the planet.
    trail_rat
    It’s only lost if you don’t have a single neighbor in you side of the transformer
    surfer
    I dont know what that means
    trail_rat
    Do you have houses in your eyesight of your house ? If so your electricity did not vanish into thin air.
    Greybeard
    It’s not lost, it’s exported to the grid, and I would be paid 3.95p/kWh for it. But IGM has a good point about a battery enabling time shifting, thanks.
    surfer
    I see.
    MrSparkle
    I’ve asked two localish firms to quote for installing systems to our bungalow.
    This is what they have come up with:
    Firm one.
    10 x 415w panels
    1 x 3.6kW inverter
    1 x 9.5kWH battery
    £9940.75
    Installed inc Vat
    £11695
    Firm two.
    12 x 405w panels
    1 x 3.6kW inverter
    1 x 4.8kWH battery
    £5860.00
    Installed inc Vat
    £9028.34
    I intend to get at least one more quote but the two systems quoted aren’t *that* dissimilar (on paper at least Firm two – battery size apart – seems ‘better’) but there’s over £2600 difference in price. What am I missing?
    surfer
    The VAT on the 2ns quote doesnt seem correct?
    The 2nd battery is double the 1st so looking at post VAT prices they appear very similar. Around £2667 for the additional 4.7kW.
    I received 5 quotes (after approaching 6 companies) and other than one outlier, and considering they were all using different kit, they were broadly similar.
    gobuchul
    What am I missing?
    Battery size.
    phiiiiil
    I think the battery is the real game changer for our system. The panels worked for a week or so before the battery did; looking at our usage over that time you can see it made a difference, but we just didn’t really need much electricity while they were generating. Once the washer’s been on a couple of times that’s pretty much it. It maybe knocked 1kwh off our normal 6-7kwh daily total.
    Once the battery was in though our import dropped like a very heavy stone, from about 5-7kwh a day to about 0.5kwh. We’re lucky in that it’s been a sunny October so far but it’s covered all our usage as we can save it up and use it in the evening when we use most power but imported power is at its dirtiest. The only time we have needed to import anything has been when the load exceeds the maximum the battery can supply. When winter hits properly we’ll fill the battery with off-peak electricity instead, which can be much cleaner than peak time electricity.
    Greybeard
    @st66
    Wh is a unit of energy, so it’s the same energy however it’s delivered. 12V 100Ah or 240V 5Ah is the same – except the inverter isn’t 100% efficient, so you lose some in the conversion, probably end up with between 4Ah and 4.5Ah.
    st66
    That makes sense. I hadn’t thought about the equivalent drop in Ah during the conversion.
    uponthedowns
    Renewables are zero vat rated now which includes the battery if its bought with panels.
    bruneep
    Firm one.
    10 x 415w panels
    1 x 3.6kW inverter
    1 x 9.5kWH battery
    £9940.75
    Installed inc Vat
    £11695
    Firm two.
    12 x 405w panels
    1 x 3.6kW inverter
    1 x 4.8kWH battery
    £5860.00
    Installed inc Vat
    £9028.34
    As said there is zero vat on renewables.
    what panels, inverter battery? if you want seg payments are they MCS reg?
    what is your average usage?
    If you can max out roof area and get a big a battery as you can.
    Why is firm one only fitting 10 when firm two fitting 12?  Ask firm one to fit 12.    Do checks on companies house on firms to see how long been on the go and local reviews on either etc etc. check check and check, lots of  🤠out there just now
