What method did you use for gluing? I’m picking up 2 tub tyres this week
This is the method I used.
Day 1 – If they are new tyres then you need to stretch the tyre, this is very important as you’ll never get the tyre on. I stretched mine for 24hrs on a clincher wheel at 50psi before I started.
Day 2 – I lightly sanded the surface of the rim and cleaned with acetone (nail varnish remover) and applied one layer to the rim and tyre base tap. (I used 1/2″ Acid Flux brushes for wpreading the glue) Layer to base tape was thick as it soaks in. I then let the glue cure on the tyre for about 30 minutes then returned to the rim and pumped up to 50 psi. The tyre sticks a little to the rim but is easy to remove.
Day 3 – Repeat day 2. You don’t need as much glue to the tyre at this stage, just a thin layer.
Day 4 – Glue to tyre then glue to rim then immediately mounted the tyre to the rim. I put about 15/20psi into the tyre to give it a bit of shape. Pumped it up to 40psi and centred the tyre and rolled it around the rim and left to dry for 24hrs.
Day 5 – Aquasure on the side walls and dry for 16 hours.
Maybe over cautious but I wanted to be sure they stuck as it was my first attempt.
A couple of vids that I used to help me.
http://www.dailymotion.com/video/xhjpen_how-to-glue-a-cyclocross-tubular-tire-to-a-303-rim_sport
