Home Forums Bike Forum The FS Drop Test
Viewing 3 posts - 41 through 43 (of 43 total)
  • The FS Drop Test
  • thisisnotaspoon
    TJ (and others) , the test accounts for different rider weights as you set the sag first then the rebound. So the heavier rider has a harder shock, so runs more rebound to stop it bouncing back up again……..
    It works, but then again i run all my bikes under sprung and under damped (i.e. fast in both strokes) by most peoples standards.
    dasnut
    I normally use my RAD-o-meter to see if my suspension is set up right.
    bigyinn
    I thought there was only one setting to a RAD-o-meter, MAX!
The topic ‘The FS Drop Test’ is closed to new replies.
