So after seeing this thread a couple of weeks ago I went ahead and ordered a set. They arrived before last weekend so was keen to get them on ready for my Sunday ride.
They went on easy enough, but air kept leaking out of the spoke holes, and could not get it to stop. Then after a quick Google it turns out my stans arch rims are only 21mm wide! I was sure I had read they were 23mm. So it looked like the valve wasn’t sitting tight down onto the rim tape, I’m guessing with the recommended rims this wouldn’t be a problem. But after some thought and lots of failed attempts I wrapped some plumbers ptfe tape round the valve to beef it up in the hope it would seal against the rim tape. And it worked! I would be amazed and impressed if anyone got them working on 19mm rims.
So I took them out for a quick trial run around the local park, no proper biking there, but plenty of kerbes and steps to ride into, running 15psi or so no rim dings or flats, so all good so far. Then off to cannock on Sunday, maybe not the most technical place, but plenty of loose corners and enough rocks to test super low pressures on a hard trail. And it all felt superb, for the first time I get that lovely soft tyre traction feeling with no puncture worries.
No idea how they will hold up long term, or if I do get a problem can I sort it out on the trail? Who knows, it won’t be easy, but fingers crossed it won’t happen. I’ll definitely be keeping them on and testing them in proper rocky terrain. I’ve been a tubeless convert for a few years now, but still run pretty high pressure to avoid dinging my rims. So this an exciting new world of learning how much soft tyres do actually stick to the dirt
I’ll report back after a few more rides.
Tom
