I just got mine off ebay.
You’ll need 2 layers for road wheels with spoke holes so it might be worth getting one tape narrower to go over the holes then the wider tape on top depending on how tight the bead seat is already.
That, and if you don’t already know, get the wheel and tape nice and warm before you start, it makes the adhesive tacky. Leave them on a radiator for a bit before you start. The glue is pressure activated so the tighter you can stretch it on, the better it will stick to the layer below.
