Home Forums Bike Forum Tapered fork 1 1/8 – 1.5 in a straight 1 1/8 Head tube?
Viewing 12 posts - 1 through 12 (of 12 total)
  • Tapered fork 1 1/8 – 1.5 in a straight 1 1/8 Head tube?
  • fotorat
    Is this for real?
    Please provide links to threads showing this or photos of your bikes done.
    Can you tell I only just realised this is possible!
    mikewsmith
    Remind me again how you get a 1.5″ tube in a 1 1/8″ Tube?
    What lube you using for that?
    nickjb
    It’ll work if the straight head tube is 44mm. You basically swap the internal bottom bearing for an external one. In a classic old skool 34mm 1-1/8th head tube it cannot be done
    PJM1974
    It’ll only work if you’ve a bike with an integrated campy headset e.g. Specialized, you can press in a lower external bearing cup into the head tube which would normally take an integrated bearing and theoretically a tapered fork will fit.
    It’ll lift the front end of your bike and the bottom bracket too, there’s a very good chance that it’ll ruin the handling.
    nickjb
    It’ll make the bike a tiny bit slacker. If it is even noticeable I suspect it would be a slight improvement unless it is already very slack.
    Ecky-Thump
    basically, just what nickjb has said.
    44mm headtube – yes
    traditional 34mm headtube – nope
    TurnerGuy
    You could do it if the steer tube was really long and you left the tapered bit of the steerer remain outside the bottom of the headtube, the bike would be a lot slacker though and would look pretty comical 🙂
    philjunior
    44mm headtube – yes
    THis
    And er yeah, you could… Might lead to quite “snappy” handling though as well as the comedy look 🙂
    How thick is the metal in a steerer? Maybe you could file it down a bit..
    stevextc
    Don’t have a photo to hand but done it… 44mm head tube on the kids bike with the Hope external.  hope adds 12mm, Canecreek do one which adds 10mm
    Depending on the fork you need different clearance/length.
    For RS forks the aluminium ones are a longer taper than the carbon.  The aluminium worked for us…  its a YMMV
    Fox have a slightly sharper taper than aluminium rockshox…
    scu98rkr
    I’ve done it on a 2010/2011 ish Boardman.
    I tend to be used to more old skool XC type frames.
    For me the change in angles had a large negative effect on the bike going up hill and trying to maintain speed.
    The extra travel was nice downhill.
    Im not sure I’d recommenced it unless you either plan to change frame soon after, or you feel the front is much too low.
    philjunior
    Well, it will lift the nose up if you up the travel AND put a 10-12mm longer lower headset cup in…
    But the 10-12mm alone will make little difference – about half a degree, or the same as running a bit less sag.
The topic ‘Tapered fork 1 1/8 – 1.5 in a straight 1 1/8 Head tube?’ is closed to new replies.
