Home Forums Bike Forum Stan's No Tubes vs Joe's No Flats – any difference?
Viewing 13 posts - 1 through 13 (of 13 total)
  • Stan's No Tubes vs Joe's No Flats – any difference?
  • poppa
    Is there any difference between the two, or any reason to buy one over the other?
    Thanks!
    poppa
    snakebite
    I have only used Stans and never had a problem.
    druidh
    I have only used Joes and never had a problem.
    foxyrider
    LOL – prob not then 🙂
    Earl_Grey
    Stans strips seem better designed to me – they sit under the bead hook on the rim, they’re a bit thicker etc. Joes strips look like bits of “pre-ghettoed” inner tube and sit in the rim overlapping the rim walls.
    Used both, never had a problem with either but for some reason I feel more nervous about Joes burping. I can’t quantify why – it’s never happened with either but I’m a complete mincer so your mileage may vary.
    RealMan
    Stans is good.
    wwaswas
    Joe’s is gooderer.
    And cheaper.
    gamo
    Used both with no problems,Joe’s strips have always fitted in under rim
    bead with me?
    Earl_Grey
    Hmmm… that might be my lack of attention to fitting then. The strip seemed a little wide to sit under the bead when I installed it. Seems to work anyway, the bonus with Joe’s is that the valve hole didn’t need drilling.
    Perhaps I should take it off and start again?
    bigyinn
    Badger badger badger??
    poppa
    Yoikes. Don’t they both use Presta valves?
    Earl_Grey
    Yes, but with stan’s the strip is thicker at the valve so the hole in the inner skin of the rim channel needs to be drilled out to 10mm to make the strip sit flush.
    It’s not difficult but is a bit extra hassle making sure an sharp bits of swarf are removed. I was slightly concerned about taking a drill to my rim the first time but it’s easy to do and allegedly doesn’t affect the rim.
    I think there’s some videos on Stan’s site…
    …here you go – Instructional videos
The topic ‘Stan's No Tubes vs Joe's No Flats – any difference?’ is closed to new replies.
