Having fun and games with my new SRAM Dub crankset at the moment.
Disassembled one last week to swap the crank. Had to apply an unbelievable amount of force just to undo the bolt. Local mechanic had already failed with a pneumatic impact driver…
Putting it back together today, tightened the bolt up and hear cracking sounds, and find that the little cup that sits between axle and bearing on the drive side has disintegrated. Perhaps it got dislodged when I put the NDS crank on and popped the axle through.
Is this repairable with a replacement cup, or is it new bottom bracket time?
Must admit that after years of having zero issues fitting and removing Shimano bottom brackets and cranks, this is all coming as a bit of an unpleasant surprise…
