Home Forums Bike Forum SpokelengthTrackWorld SP Dynamo hub to Mavic TN317
Viewing 11 posts - 1 through 11 (of 11 total)
  • SpokelengthTrackWorld SP Dynamo hub to Mavic TN317
  • mcmoonter
    I’m going to build up a new front wheel for my Fargo with a Shutter Precision dynamo hub and a Mavic 32H TN317 rim.
    The rim ERTO is 622
    Hub dimensions are here.
    http://leonard.io/edd/hub/1299-sd-8-shutter-precision-dynamo-front
    If anyone has a spare minute could they double check the spoke lengths for me.
    I will have a bash just now too.
    mcmoonter
    I ended up with
    L 302mm R 302.9mm
    Stoner
    STOP!
    you dont want the ERTO, you want the ERD, which for the TN317 is 600mm by the look of it.
    are you thinking 2 cross for the front or 3 cross?
    Stoner
    and looking at your numbers (302mm) it seems youve gone for 3x with the wrong ERD (622mm)
    3x with an ERD of 600mm comes out at 290mm/291mm
    So Id just get a box of 291mm. if they do them in odds, or 290mm if only evens.
    mcmoonter
    Oops
    3 cross spokes.
    Cheers Stoner.
    bristolbiker
    Stoner’s numbers sound about right – think I ended up/got away with 292mm on both sides of an LX dynamo disc hub, 3 cross on an Open Pro.
    boblo
    Out of interest McMoo, why did you go for this rather than the magic Rose Shimano N80/317 combo @ £60? Just curious.
    mcmoonter
    Boblo, mostly vanity* and the love of bling.
    *matching the rear rim.
    boblo
    That’s the most compelling reason after all 🙂
    mcmoonter
    I needed it to have a disc hub too. The Rose bike wheel is great value, I might still go for one for my Harry Hall.
    thomthumb
    i built mine 290 all round. worked fine.
    I measured ERD at 599. EDIT: mine was tn319. So ignore me. maybe
The topic ‘SpokelengthTrackWorld SP Dynamo hub to Mavic TN317’ is closed to new replies.
